Author Topic: GVP 7.6 IP change  (Read 2373 times)
Offline CTIgem
GVP 7.6 IP change
« on: December 10, 2009, 01:50:27 PM »
After installation of GVP 7.6, we'd like to change ip address on the servers.
Can this be done without affecting anything on the working GVP 7.6?
Thanks.
Re: GVP 7.6 IP change
« Reply #1 on: December 10, 2009, 02:15:34 PM »
yes as long as you always used fqdn
Offline GenesysNewbie
« Reply #2 on: December 10, 2009, 03:13:18 PM »
um.. if i remeber thsi well, on the wirzard u enter ip adrresses in most cases,  that information is stored on SunOne Ldap, maybe if u change ur addresses ur solution doesnt work.
Hope this help.
« Reply #3 on: December 10, 2009, 03:27:32 PM »
Sun LDAP is only for big deployments, even in that way the server itself will not be affected, only minor configurations, so again, if he used FQDN then will be no problem.
Offline CTIgem
« Reply #4 on: December 14, 2009, 11:26:35 AM »
Thanks, I'll try to stick with fqdn and change.
