Author Topic: how to test DLG connection.  (Read 3324 times)
geni1
« on: December 10, 2009, 08:35:33 AM »
I'm going to depoyment Framework 7.6 , Tserver will connect with AES via DLG .
Is there any testing tool which I can test the CTI link and AES connection ? how do I know the link is configured properly ?
Thanks in advance  ??? ???
Marked as best answer by on October 08, 2024, 07:43:51 PM
IanDS_
Re: how to test DLG connection.
« Reply #1 on: December 10, 2009, 01:06:34 PM »
  • Undo Best Answer
  • Well the first thing is to make sure it is configured on the tserver correctly and that you are getting an eventlinkconnected message back.
    Its pretty easy to get a connection..... once you get that there rest is all from Genesys side, except maybe depending on how you want to handle TACW and RONA.
    Ian DS
