Author Topic: GVP Proactive and URS ::: S.O.S. :::  (Read 4323 times)
Offline GenesysNewbie
« on: December 10, 2009, 01:54:11 AM »
hi guyz, how r u...please help me to understand the following. so sorry , but i need ur help 2 clarify.
I am configuring a power gvp campaign, in its options a Voice transfer is required. This voice transefer is a RP.
Lets think RP = 78087.
In this RP i need a strategy routing for example to a Gruop of places or can i leave it in blank????  (If not, how does the call arrives to the gvp ports???)
i perform a couple of call by ocm and monitor the RP its is always on "0" does not matters how many call does OCM dials.
thanks for all the patiente guyz...
Re: GVP Proactive and URS ::: S.O.S. :::
« Reply #1 on: December 10, 2009, 04:17:02 AM »
The voice transfer is only needed if you plan to transfer the call to an agent
« Reply #2 on: December 10, 2009, 04:46:41 AM »
ok cav...
Additional Q.
If u do not have a strategy , how can u obtenin the conId???? i was planning 2 attach it, but without a strategy seams is not possible...
« Reply #3 on: December 10, 2009, 05:06:49 AM »
again, GVP does the dialing using IPCS or VCS not the TServer. So there is no ConnID there. The connID will begin when you transfer to a RP to select an agent, why do you want to attach the ConnID?
« Reply #4 on: December 10, 2009, 05:12:54 AM »
Cav, friend...at this time i disagree.For every call i place on OCM y see a conID on tserverIVR logs.
Its a customer requirement =...(
Offline Fra
« Reply #5 on: December 10, 2009, 03:03:39 PM »
See my answer in the other thread you opened.
If you want to transfer the call from GVP to agents, you need at least a routing point; no matter whether you have a strategy loaded on it, you need to configure an outbound agent group, add that routing point as Voice Transfer Destination, add the OBN Manager and the routing Stat Server to its connections. And then..well, it's up to you what to about the call after has been transferred there! :P
Fra
« Reply #6 on: December 10, 2009, 03:11:11 PM »
hi fra than k u very much, i aprecite ur time.
what is the objective of this Voice transfer, i read on manual i need to configure it, but if i select none, the calls still arrive. That why i am sooooo confused. ???
Offline Fra
« Reply #7 on: December 10, 2009, 03:18:08 PM »
The question is, what do you want to do about the call once has been processed by the VXML application?
If you want to transfer it somewhere, you need an agent group and VTD.
Fra
« Reply #8 on: December 10, 2009, 03:22:44 PM »
[quote author=GenesysNewbie link=topic=4982.msg22170#msg22170 date=1260421974]
Oh so you are using TServer IVR...that is another thing. Even it is not mandatory for OBN with OCS...as Fra mentioned the transfer destination is an OCS functionality, maybe if you read the OCS documentation will get a better idea, but again TSERVER IVR is not needed even in this case.
« Reply #9 on: December 14, 2009, 03:01:38 PM »
ok guys!!
i understand the idea about using RP is only to transfer agents, its clear 4 me.
Thanks for ur time and patiente.
(..Y dale U...)
