Author Topic: config UCSDAP in the way of oralce  (Read 3501 times)
kay
« on: December 08, 2009, 05:17:37 PM »
hi
    When i deploy multimedia , the database is oracle, i config the UCSDAP with the oracle database and multimedia and database don't deploy on one PC. Must I install LCA in the System of oracle ,so we can monitor the PC of oracle.
Re: config UCSDAP in the way of oralce
« Reply #1 on: December 08, 2009, 06:21:18 PM »
  • If you want to monitor that server yes, otherwise just create the host in CME and use it for your DAP
    « Reply #2 on: December 09, 2009, 09:04:18 AM »
  • Kay,
    If you set LCA port to 0 (zero) for this host then SCS won't monitor it so no alarms of type host unavailable/inaccessible will be generated.
    kay
    « Reply #3 on: December 09, 2009, 11:35:23 AM »
  • hi cavagnaro
          You means I must install LCA on the PC of oracle? but if the OS of oracle is windows XP , it seems LCA doesn't support this OS. So when i config UCSDAP(contact server) in multimedia,can you tell me how can i config the UCSDAP with the way of JDBC.
    « Reply #4 on: December 09, 2009, 12:38:26 PM »
  • Kay,
    LCA is optional component so deployment on Oracle server is not required. Follow these steps to create JDBC-based DAP for UCS:
    1/ Create new host with name corresponding to your Oracle host in CME. Set LCA port to 0 - SCS won't try to monitor that host
    2/ Create new DAP as described in Multimedia Deployment Guide on page 109 (key points - DBServer must not be selected, fill connection information on "Database Information" tab, select Oracle host, you've created in step 1, and set port to 1521 on "JDBC Connection" tab)
    kay
    « Reply #5 on: December 11, 2009, 01:37:46 PM »
  • hi René
          Thank you!
