Author Topic: Dialogic JCT 600 Xpress Problem.  (Read 3470 times)
Offline GenesysNewbie
« on: December 03, 2009, 02:39:45 PM »
hi guys, please need ur help with the following. I have this JCT board but the dialogic driver seems not to be working.
I think i need other jct driver for PCI XPress. PLEASE POINT IF THIS IS CORRECT
Normally i installed JCt boards but por PCI (i mean not PCI Xpres) and the driver works pretty fine.
GVP 7.6 -Driver 6.0 Build 218.
Additional information , i can confirm the OS is recognizing the board as HW, cause i can see it on MyPC-RigthCLick-Advance-HW but when try to startup teh board the dialogic GUI does not show the board.
The questions is, Does somebody installed this kind of boards????????? If yes, please i aprecite if u can point ur driver version.
Offline CTIgem
Re: Dialogic JCT 600 Xpress Problem.
« Reply #1 on: December 07, 2009, 02:35:04 PM »
I see JCT 600 E1 type is supported but not T1.
Are you using T1?
« Reply #2 on: December 07, 2009, 02:42:49 PM »
Hi friend.
E1-Cas.
I think teh driver does not support thatkind of board (with pci xpress)
HAve u tested a board like this????
Offline CTIgem
« Reply #3 on: December 07, 2009, 09:02:10 PM »
I'm using DMV 600 PCI express, T1.
I't working fine for me.
« Reply #4 on: December 07, 2009, 09:15:11 PM »
um u have dmv t1..
well isee is a total differente sceanrio , i have jct 600 pci xpress e1
and it does not work.
what version of driver do u installed?
