Author Topic: CCPulse total_time_to_answer stat  (Read 3457 times)
Offline CTIgem
« on: December 03, 2009, 02:32:55 PM »
How do I bring in total_time_to_answer (VQ) stat in the CCPulse predefined stat available window?
Thanks.
Re: CCPulse total_time_to_answer stat
« Reply #1 on: December 03, 2009, 04:21:27 PM »
Create a new template with that Stat or modify the existing one
Offline CTIgem
« Reply #2 on: December 03, 2009, 07:48:48 PM »
I mean how do I make total_time_to_answer show up in available statics as shown in attachement.
« Reply #3 on: December 03, 2009, 09:21:45 PM »
Maybe it is not considered for that Subject...check in DMA
tony
« Reply #4 on: December 04, 2009, 12:50:28 PM »
It looks like you have a section missing, for Total_Time Stats...
[quote author=CTIgem link=topic=4966.msg22102#msg22102 date=1259869728]
Offline catanirex
« Reply #5 on: December 04, 2009, 01:28:37 PM »
Do you have the statistic define under options on your StatServer used for CCP?
If not - add it and restart CCP.
