Author Topic: Wizard fields are Black on Black  (Read 2516 times)
Offline mlow
« on: December 03, 2009, 01:54:26 PM »
When I use any of the upgrade wizards (Wizard Manager). I select the option on the left pane, (Upgrades) I then select the checkbox to "Show Individual Applications". Then I select an app that can be upgraded, ( like outbound contact server) when the window opens for the upgrade of the selected app (all of the apps do this) the text and background are Black On Black and I can't read what it say's in the fields. Do you know what file has the background/font color for the Wizards? I have searched in the GCTI file on my PC and have found the ccwbl xsl stylesheet, but I don't want to mess up the app if that is the wrong file to change the font/background color of the fields. I have also tried to uninstall and install the wizards and have checked the versions....Everything seems ok but I still can't see the information in the fields.  ???
« Last Edit: December 03, 2009, 04:46:03 PM by mlow »
tony
Re: Wizard fields are Black on Black
« Reply #1 on: December 04, 2009, 12:52:12 PM »
....it may be set in the colour scheme on your Windoze screen.... ? Have you tried viewing the screen on another PC...?
Tony
Offline mlow
« Reply #2 on: December 14, 2009, 04:32:29 PM »
yep I checked on two other pc's. I tried to modify my color settings to no avail...it seems like it is part of the wizard itself. Does it show black on black for you?
