" /> select DB_Prompt field type - Genesys CTI User Forum
Author Topic: select DB_Prompt field type  (Read 3591 times)
GVP_Newbie
« on: December 02, 2009, 04:59:48 PM »
I'm developing a GVP application (7.6) and using DB objects, my goal is to be able to play a column but in money format, right now it is reading it like canonical format which is wrong. Do you have any idea how to achieve it?
Re: select DB_Prompt field type
« Reply #1 on: December 02, 2009, 05:25:43 PM »
  • Be sure that the field in the table is on currency format
