Hi guys,
One of my customers would like to have HA for everything, I have found this about FlexLM:
[quote]
Setting up Redundant Servers
To set up redundant servers, you must provide the hostid for three machines to your software vendor, who will in return give you a license file with three SERVER lines. You need to make sure that each license server has lmgrd, the vendor daemon program and the license file on a local file system. (For some caveats on remote file systems, see Section 5.2, `Diskless Nodes and Remote Mounted Disks,' on page 27). You then start lmgrd on each license server.
Quorums and Redundant Servers
In a redundant server configuration, no licenses are available until there is a quorum of servers. A quorum of servers is defined as a strict majority of the servers listed in the license file, so a quorum in a three-server configuration is two. In other words, if only one server in a three server configuration is running, then no licenses will be available. As soon as two of the three servers are running and communicating with each other, then all of the licenses will be available.
Have anybody applied a similar configuration? Also is there any chance to configure more than one FlexLM server on Genesys applications?
Thanks for any ideas you may have
