Author Topic: Configuration SDK Doubts  (Read 2940 times)
Offline Prassytheone
« on: December 01, 2009, 11:22:55 AM »
Hello All,
I am new to GIS and I am writing a simple C# .NET application which interacts with the GIS to get information from the CME to update the details.
I am following the code as mentioned in the Configuration SDK 7.2 Web Services dev guide and i am able to connect to the Config Service successfully but when retriving the data ,am facing the following issues :
  1. I have added the web reference successfully for Session Service, Stat Service and Config Proxy ,i am trying to use the following methods after getting the session ID:
        DisplayResults(queryAgents,(XmlElement)cfgService.get(queryAgents)), - says there is no such method found.
  2. I am using GIS 7.5 and trying to retrieve values from CME 7.2 will this be a problem??
  3. Will i be able to retrieve the T-Server options using the GIS- Config proxy once i get the connection, do we have any document for this?
Any help regarding the above query will be helpful and apologies if the query seems basic :)
Prassy
Re: Configuration SDK Doubts
« Reply #1 on: December 01, 2009, 08:44:44 PM »
Hi Prassy,
[quote]1. I have added the web reference successfully for Session Service, Stat Service and Config Proxy ,i am trying to use the following methods after getting the session ID:
        DisplayResults(queryAgents,(XmlElement)cfgService.get(queryAgents)), - says there is no such method found.[/quote]
Have you created the method DisplayResults? You can find the code in Developers Guide.
[quote]2. I am using GIS 7.5 and trying to retrieve values from CME 7.2 will this be a problem??[/quote]
There should be no problem as Genesys usually maintains backward compatibility.
[quote]3. Will i be able to retrieve the T-Server options using the GIS- Config proxy once i get the connection, do we have any document for this?[/quote]
Yes. You should use the method "Get". XPath query should look like this one "CfgApplication[@name='...name of your T-Server app']".
PS. You should use Developer's Guide for release 7.5 as you have GIS 7.5 and not 7.2.
« Reply #2 on: December 02, 2009, 02:58:34 AM »
Hello Rene,
Thanks for your reply :) ill follow the hints given by you and proceed and to answer your 1st Question, i had created a method after referring to the dev guide and as suggested ill look at 7.5 rather than 7.2 :)
Cheers,
Prassy
