Author Topic: EMPS connection with other GVPs  (Read 2209 times)
Offline aponterules
« on: November 25, 2009, 06:34:39 PM »
Hi
I have a customer with 4 GVPs, 1 box has installed GVP and EMPS (for the 4 GVPs), 3 boxes with GVP, 1 GVP each one, I know that all GVPs ask the EMPS for the config and xml applications but in case the customer changes or modifies the Windows Administrator password of the server with EMPS installed, I think the other 3 GPVs won´t be able to connect to the EMPS, so I´m not sure where do I need to declare the new password on the others GVPs
I think its under IIS/web sites/dispenser? But I´m not sure if its under the anonymous access?? Or where do I need to stablish the new windows password of the server running the EMPS, in order to GVP connects to that server
Or, how is the connection between GVPs to EMPS running on a separate server??
Offline CTIgem
Re: EMPS connection with other GVPs
« Reply #1 on: November 25, 2009, 09:06:40 PM »
Well, I thought VCS or IPCS server registers with EMPS and it's not related to Windows admin password.
And this means as long as you don't change EMPS user name and password, you should be ok.
I didn't test this so someone else might have more info.
