Author Topic: [manage log file] One log file per call instead of rotating file by size  (Read 3037 times)
sp31415
At the moment, the log file of the popgateway are configured to be a rotating file by size.
I am configuring an development environnement, so I would like to have an file per call.
I didn't see anything about something like that...
Is it possible ?
if it is possible how ?
Thank you for your help...
Serge
Re: [manage log file] One log file per call instead of rotating file by size
« Reply #1 on: November 25, 2009, 02:41:04 PM »
Not an option unless you create your own parser somehow.
Marked as best answer by on October 24, 2024, 08:28:28 AM
sp31415
Thank you very much for your answer...
I was fearing something like that...
Regards,
Serge
Offline bogdan
« Reply #3 on: November 25, 2009, 03:28:22 PM »
or you may try kazimir tool (available on the support website)
