Author Topic: GAD - Email clarification  (Read 6243 times)
rita
« on: November 19, 2009, 05:30:14 PM »
Hi All,
I'm testing email interactions to GAD (Genesys Agent Desktop)
Able to route a email to genesys agent desktop from outlook client.
Outlook is using POP3 for retrieving emails and smtp for submitting emails.
When i try to reply to the interaction -From field which is a dropdown is not populated and not editable to provide some email address. It is the same when i try to send the email too. it prompts an alert -"Invalid From Email Address".
I tried setting up in agent info tab in CME for the agent. but no luck.
Can anyone help from where this  "From" field gets populated
Re: GAD - Email clarification
« Reply #1 on: November 19, 2009, 05:34:14 PM »
In Email server you setup the mail accounts, (pop-client section) but GAD should populate those informations from the email headers.
rita
« Reply #2 on: November 19, 2009, 06:51:05 PM »
I tried to configire the "default-from-address"  under Multi-media section as per Genesys desktop deployment guide the but it is populated in GAD .
« Reply #3 on: November 19, 2009, 07:34:25 PM »
Will have to see the IServer and Email server logs to try to understand you better.
Marked as best answer by on Today at 10:34:08 PM
rita
« Reply #4 on: November 20, 2009, 10:41:20 AM »
  • Undo Best Answer
  • Hi cavagnaro ,
    Please find attached the screenshots...
    1. Incoming email to GAD
    2. Not able to reply because From field is not populated so it alerts "Invalid From E-mail address"
    Have already  set up mail accounts in Pop3 and it is configured in Email server under pop-client section,
    Assume the mail is sent from customer to Agent (Incoming mail) and agent tries to reply .
    Need to associate email to agents in GAD.
