Author Topic: ACW after Inbound call and after Outbound call  (Read 3194 times)
Offline Lukas
« on: November 12, 2009, 08:58:52 AM »
I new here and I have two questions:
1. Is possible to get one statistic of ACW time after Inbound calls and second statistic of ACW time after Outbound calls?
2. Is any possiblity how to get ringing time? I mean how long where inbound call ringing after distribution from queu.
I will really appreciate your help.
Thanks a lot
Lukas
« Last Edit: November 12, 2009, 09:19:34 AM by Lukas »
Re: ACW after Inbound call and after Outbound call
« Reply #1 on: November 12, 2009, 09:42:59 PM »
Yes you can, create new stat types in the StatServer with MainMask = AfterCallWorkInbound and AfterCallWorkOutbound.
« Reply #2 on: November 15, 2009, 04:16:11 PM »
Hello Lukas,
Masks mentioned by Cavagnaro can be used but there are some important limitations or conditions related to these. I would suggest you to read section dedicated to AfterCallWork action in StatServer User's Guide (page 69).
To your second question - I think there are two ways to get required information (ringing time). You can define new statistic with mask CallRinging or you can use following formula - [i]TimeToAnswer - TimeToDistribute[/i].
PS. Ahoj :)
