Author Topic: CCPulse Template  (Read 3382 times)
Offline PFCCWA
CCPulse Template
« on: November 07, 2009, 12:17:02 PM »
Is it possible to hide a statistic within a ccpulse (v75) template?
I want to add a forumula using the answered and abanonded statistics, but dont want to display the abandoned one.  I do have to use both in the template to create the formula though.
Is this possible?
WA
Offline ecki
Re: CCPulse Template
« Reply #1 on: November 08, 2009, 08:22:50 AM »
You can hide column in report view opened in workspace. Right click on the column and select hide from the pop-up menu.
