Author Topic: Eserver to get statistics on EMap  (Read 2253 times)
Offline Rose
« on: October 20, 2009, 03:22:00 PM »
Hi All,
Do anyone have an idea on EServer.
I could see through logs, that my Eserver is talking to statserver, but does not show up on EMAP which is gui.
Regards
Rose
Offline nishantank
Re: Eserver to get statistics on EMap
« Reply #1 on: October 20, 2009, 04:13:03 PM »
Rose
The EServer & EMap is a custom application built by iGATE for its clients.
This forum will not yield you any answers for EServer related questions.
I guess you should raise a ticket with iGate support for resolution to your problem.
Regards
Nishant Tank
Offline Rose
« Reply #2 on: October 20, 2009, 04:31:09 PM »
Hi Nishant,
Thanks for  your prompt reply.
iGate is a solution provider for Genesys?
I have to fetch Stats for my customized softphone
Could you please tell me any info about eClient/eServer/
any kind of help would be highly appreciable
Regards
Rose
Offline nishantank
« Reply #3 on: October 20, 2009, 04:53:04 PM »
Hi Rose
Yes - iGate is a Solution Provider for Genesys.
Which organization do you work for  - NOVA, Seimens, .... ???
Well, eServer/eClient is a iGate product developed using VC++. It basically connects to the Stat Server and picks up stats to be displayed on eClient.
I am not very familiar with this product of iGate. But I know that it is an iGate custom product because I used to work for iGate.
There is a support division with iGate to whom your query should be forwarded.
I guess there is some mapping to be done in order to be able to see the stats on the eMap.
As I said, you will need to contact iGate support.
Regards
Nishant Tank
