" /> WFM Web Issue - Genesys CTI User Forum
Author Topic: WFM Web Issue  (Read 3314 times)
Offline zack31
WFM Web Issue
« on: October 14, 2009, 10:11:09 PM »
Hey all - have come across something bizarre which release notes don't seem to make a mention of. User on WFM Web 7.6.000.18 is having issues saving schedules. When user does, other users cannot see his changes. Similarly, in the past, if a user did make changes to schedule and saved them, it undid any changes another user had made!
Have checked permissions/ranks etc in CME and Config Utility - the user is in all the right places but am trying to figure out what else I may need to look at to assist the issue.
For the record, here are the other app versions:
WFM Builder - 7.6.000.18
WFM Daemon - 7.6.000.04
WFM Data Aggregator - 7.6.000.05
WFM Server - 7.6.000.15
WFM StatServer - 7.1.000.20
Any help is greatly appreciated!! :)
Offline Timur Karimov
Re: WFM Web Issue
« Reply #1 on: October 15, 2009, 07:52:08 AM »
Hi zack
May be it's not you case, but WFM Server version early then 7.6.100.44 contain this bug: "Schedule updates are now instantly visible to all clients. Previously, schedule updates were sometimes delayed for some clients when using a multiple-server configuration for load balancing"
hope it can help you,
WBR Thaler
Offline zack31
Re: WFM Web Issue
« Reply #2 on: October 15, 2009, 11:01:44 PM »
Thanks for the advice however I have discovered that the user was not committing the changes after saving them hence why the agents were not able to see them - user error essentially!
Thanks again:)
Re: WFM Web Issue
« Reply #3 on: October 16, 2009, 06:24:06 AM »
LOL  ;D
