Author Topic: Genesys Desktop  (Read 2810 times)
Offline lekie
Genesys Desktop
« on: October 06, 2009, 09:52:30 AM »
Dear All,
            How can I config GAD to connect to config server proxy?
I want to test the system if my config server primary and backup is down but proxy is still working fine.
Thanks you in advance,
Cheers,
Lekie
Offline Steve
Re: Genesys Desktop
« Reply #1 on: October 06, 2009, 11:37:21 AM »
Edit the configServerHost value in the web.xml file on the server running the war file.
Offline Timur Karimov
Re: Genesys Desktop
« Reply #2 on: October 07, 2009, 07:48:24 AM »
One things what u mast keep in mind!
GAD use the configured backup config server only then start, not while it's running. It CAN'T switch to the backup config server during their work.
WBR Thaler
Offline lekie
Re: Genesys Desktop
« Reply #3 on: October 08, 2009, 02:58:47 AM »
Thanks you so much
