Author Topic: APP_STATUS_UNKNOWN  (Read 4630 times)
genesys Rookie
APP_STATUS_UNKNOWN
« on: October 05, 2009, 07:10:49 PM »
What does it mean when an application goes to unknown state?
example :
I see in CSI that  App= datasourcer  Status= unknown when the normaly state itīs Primary/Backup.
Can you help me to understand this ?
Regards
Offline uho001
Re: APP_STATUS_UNKNOWN
« Reply #1 on: October 05, 2009, 07:31:59 PM »
  • Do you have LCA running on that machine? my understading is that if LCA is not running properly you wont get the status of your application.
    Genesys Rokkie
    « Reply #2 on: October 05, 2009, 07:39:09 PM »
  • Yes I have the LCA in that machine and running perfectly, I think ???
    Offline Steve
    « Reply #3 on: October 06, 2009, 12:06:18 PM »
  • Could it be a network issue? Between the SCS host and the datasourcer host.
    Does the datasourcer host also go unknown? What about any other apps running on that server.
    Genesys Rookie
    « Reply #4 on: October 07, 2009, 05:04:23 PM »
  • This is the error that appears in the log
    [color=red] #### WARNING: App not responded in 20 seconds on Request
    Notify STATUS: App <166, datasourcer_b, pid = 17,568, APP_STATUS_UNKNOWN, BACKUP. [/color]
    Have something to do this??
    In the CME, the configuration of the App "DataSourcer_b" has a "Reconnect Timeout of 10 seconds" and "reconnect Attempt 1" and the response time exceeded  + 20 seconds.
    In contrast, the primary DS has the values 12 and 12 on both items.
    Regards
    Offline Fra
    « Reply #5 on: October 09, 2009, 10:42:05 PM »
  • [quote author=Genesys Rookie link=topic=4746.msg21253#msg21253 date=1254935063]
    Yes. If an application can't be successfully started by LCA, the application status reported to SCS that you can see in your SCI GUI is "unknown".
    Reasons for that could be several.
    1. check whether your LCA is installed, up and running on that box
    2. you may want to enable its logging (check the Management layer guide for help)
    3. check whether that host status is "up" in SCI
    4. start the application manually from the box and verify whether you have the same issue
    Is the Datasourcer host a UNIX or Windows one?
    Fra
