" /> Config Server error - Genesys CTI User Forum
Author Topic: Config Server error  (Read 2317 times)
Offline jingoi
Config Server error
« on: October 05, 2009, 07:49:44 AM »
Configuration Manager cannot connect to database,it may be because of DATA BASE password change and not updated in Configserver Configfile
could any budy tell me how to update password in cofig file ..
password shows in encrypt form
Offline catanirex
Re: Config Server error
« Reply #1 on: October 05, 2009, 08:45:58 AM »
You can remove the encrypted pw and add the new one in clear if you want to fix it quickly.
Otherwise, please look at section "Encrypting the Configuration Database Password" in Framework Deployment Guide.
