Author Topic: Help with GVP logs...  (Read 5256 times)
Offline BenTaylor
« on: July 24, 2009, 10:52:35 AM »
GVP 7.6 behind (Avaya VOIP)
I cannot seem to get this working at all, can someone have a look at these log segments and try and give me some pointers please...
First off I'm not getting DNIS, I can live with that for now and have setup default DNIS (7192). Why is this call being rejected??
Popgateway log:
[2009/07/24 10:40:09.031] 17F8 HangupCall.cpp:157 C=12:L=2:U=321:D=W_12_93 CFC rejected the call [ ANI=$ani$ DID=7192 TollFreeNum=8888 Reseller=GVPOwner Customer=Admin Application=GVP_ACI SessionID={184B5835-40F6-4A54-8D76-8C77CAB8F11A} LastError=$last-error$ LastErrorString=$last-error-string$]
[2009/07/24 10:40:21.639] 17F8 ConversationController.cpp:1590 C=3:L=2:U=0:D=W_3_82 Informed CFC about Leg going down
GVPOwner_Admin_GQA log:
[2009/07/24 10:40:09.015] 10FC GetCallInfoAction.cpp:228 C=14:L=1:U=1413 Session ID[{184B5835-40F6-4A54-8D76-8C77CAB8F11A}] : Timeout waiting for Ringing event from IServer.
[2009/07/24 10:40:09.015] 10FC GetCallInfoAction.cpp:276 C=14:L=2:U=0 Ringing event did not received may be got ENDCAUSE as 'FeatureNotSupported'
CFA log:
[2009/07/24 10:40:09.015] 6B0  LocalService2.cpp:1157 C=14:L=2:U=1006 DNIS not passed by IServer Client. Using default DNIS : RESULT=SUCCESS&ANI=&DNIS=&unicode=yes, Query : notifyprocess=CFA&LEGID=CC61363144000&POP_SVR=http://localhost:9810/webnotify.asp&POP_GW=PopGateway1&LATANAME=$lata-name$&SESSIONID={184B5835-40F6-4A54-8D76-8C77CAB8F11A}&tfn=8888&DID=$did$&ANI=$ani$&CC.NEXTACTION=PROCESS_INCALL&appname=$application-name$&customername=$customer-name$&customerid=$customer-name$&PrimaryQAURL= &BackupQAURL=$backup-qaurl$&QdeviceEnabled=0&ConfirmWithQA=0&DefaultRouteNum=$defaultroutenum$&DialPlan=0&CpaTimeout=0&resellername=$reseller-name$&ContactCallRtr=$contact-call-router$&IvrPortNum=5
« Last Edit: July 24, 2009, 10:55:34 AM by BenTaylor »
Offline CTIgem
Re: Help with GVP logs...
« Reply #1 on: July 24, 2009, 12:39:20 PM »
Is your Iserver up and running?
Please post your TserverIVR and Iserverclient log.
Offline BenTaylor
« Reply #2 on: July 24, 2009, 01:23:28 PM »
Yes, everything looks to be running
Heres the TServerIVR log, couple of odd lines highlighted...
11:40:05.016 Trc 29043 Received message 00.00.00.1d:00.00.00.83:New Call Network.
@11:40:05.0160 [tcl:DEBUG2]: TimerManager::startTimer: local id: 2 , conn id: 989855775 , period: 28800000
@11:40:05.0160 [tcl:DEBUG]: TclHandler::copy_value : IN_MSG [ GLI.Group ] -> USER_DATA [ GLI.Group ]
@11:40:05.0160 [tcl:DEBUG]: TclHandler::copy_value : IN_MSG [ GLI.Circuit ] -> USER_DATA [ GLI.Circuit ]
@11:40:05.0160 [tcl:DEBUG]: TclHandler::get_value : IN_MSG [ XML.Message.GctiMsg.NewCall.CalledNum.Val ] = String(05)
@11:40:05.0160 [tcl:DEBUG]: TclHandler::get_value : IN_MSG [ XML.Message.GctiMsg.NewCall.Attrs.Version ] = String(4.0)
@11:40:05.0160 [tcl:DEBUG]: TclHandler::get_value : IN_MSG [ XML.Message.GctiMsg.NewCall.ANI.Val ]: set to default val:
@11:40:05.0160 [tcl:DEBUG]: TclHandler::get_value : IN_MSG [ XML.Message.GctiMsg.NewCall.DNIS.Val ]: set to default val:
[color=red]@11:40:05.0160 [tcl:DEBUG]: TclHandler::value_exists : ENV_DATA [ TLIB.DNList.05 ] does not exist[/color]
@11:40:05.0160 [tcl:DEBUG]: TclHandler::get_value : IN_MSG [ GLI.Group ] = Int(-1)
@11:40:05.0160 [tcl:DEBUG]: TclHandler::get_value : IN_MSG [ GLI.Circuit ] = Int(1)
@11:40:05.0160 [tcl:DEBUG]: TclHandler::get_value : IN_MSG [ XML.Encoding ] = String(utf-8)
@11:40:05.0160 [tcl:DEBUG]: TclHandler::set_value : USER_DATA [ DestEncoder ] = String(UTF-8)
@11:40:05.0160 [tcl:DEBUG]: TclHandler::copy_value : IN_MSG [ XML.Message.GctiMsg.CallId.Val ] -> USER_DATA [ CallID ]
[color=red]@11:40:05.0160 [tcl:DEBUG]: New call rejected on CalledNum: 05 (called number not configured)[/color]
@11:40:05.0160 [tcl:DEBUG]: TclHandler::queue_event  creating internal event: InternalStopIServer ( 00.00.00.1d (null) )
@11:40:05.0160 [tcl:DEBUG]: TclHandler::create_msg : Created message: ( 00.00.00.1d 00.00.00.84 )
@11:40:05.0160 [tcl:DEBUG]: TclHandler::get_value : IN_MSG [ XML.Message.GctiMsg.CallId.Val ] = String({184B5835-40F6-4A54-8D76-8C77CAB8F11A})
@11:40:05.0160 [tcl:DEBUG]: TclHandler::get_value : USER_DATA [ DestEncoder ] = String(UTF-8)
@11:40:05.0160 [tcl:DEBUG]: TclHandler::set_value : OUT_MSG [ XML.Raw ] = String(<?xml version='1.0' encoding='UTF-8'?><!DOCTYPE GctiMsg SYSTEM 'IServer.dtd'><GctiMsg><CallId>{184B5835-40F6-4A54-8D76-8C77CAB8F11A}</CallId><EndCall EndCause='FeatureNotSupported'/></GctiMsg>)
@11:40:05.0160 [tcl:DEBUG]: TclHandler::copy_value : USER_DATA [ GLI.Group ] -> OUT_MSG [ GLI.Group ]
@11:40:05.0160 [tcl:DEBUG]: TclHandler::copy_value : USER_DATA [ GLI.Circuit ] -> OUT_MSG [ GLI.Circuit ]
@11:40:05.0160 [tcl:DEBUG]: TclHandler::set_value : OUT_MSG [ RouteDest ] = String(ivr)
11:40:05.016 Trc 29044 Sent message 00.00.00.1d:00.00.00.84:EndCall.
« Reply #3 on: July 24, 2009, 02:26:06 PM »
Hi Ben,
Your issue is caused by wrong GVP configuration in CME thus IVR T-Server rejects incoming calls. I can see in the snippet of IVR T-Server log that GVP ports are numbered 01,02,03... I think (99% - don't have access to Avaya/GVP system now) it's wrong as port number has to match extension number mapped to this GVP port (port 1234 = extension 1234).
Offline BenTaylor
« Reply #4 on: July 24, 2009, 02:29:06 PM »
It looks like somebody forgot to specify the IVR Server Interface to the IVR...  ::)
I hate picking up when people go on holiday....
Offline GenesysNewbie
« Reply #5 on: August 28, 2009, 01:51:04 PM »
hi guys,
Please i really aprecite if u can point what type of DN r u using for avaya.
For sure  u  r using VoiceTreatmentPorts ... rigth?
Well, my problem is taht i want 2 implement autologin functionality, i only did this for( ACD Position on Nortel). Do u know if it is posible to implement something similar in Avaya?
Offline smol
« Reply #6 on: October 02, 2009, 01:52:44 PM »
You can create ACD Postion type for Avaya.
For the Auto-Login; create a AutoLogin section on the AnnexTab of your IVR Ports with these options (put your values)
[AutoLogin]
AgentId=11800
Password=435E5C364F1AE734C2336A0B6B1FA5DB
Queue=16920
SetLoggedIn=true
SetReady=true
