Author Topic: Apllication Block and Attached data  (Read 3554 times)
Offline boudou
« on: July 12, 2009, 03:13:50 PM »
Im trying to retrieve the attached data of an interaction with the use of ApplicationBlocks but the solution proposed to enother thread with the use of [b]"GetInteractionAttachedData"[/b] dosent seam to work since i cant find it at voiceinteraction or in interaction.batch event argouments
thanks on advance
/cheers
Re: Apllication Block and Attached data
« Reply #1 on: July 13, 2009, 05:25:08 AM »
what are you using for your Voice SDK? Are you programming in C# or Java? Also, what version?
Offline boudou
« Reply #2 on: July 13, 2009, 06:22:14 AM »
hi,
im progrming in c# with version 7.6
/cheers
Offline boudou
« Reply #3 on: July 15, 2009, 06:27:53 AM »
well cancel that, i went with the sdk way not using the Interaction block and got all the information
cheers
