Author Topic: pegging a VQ  (Read 3740 times)
Offline RDB
pegging a VQ
« on: June 12, 2009, 10:12:11 AM »
hi all,
i am a newbie in genesys routing and not sure abt the
following:
what exactly pegging a VQ means?
And while targeting an agent or AgentGroup,
y do we use .A or .GA after the agent or AG name?
Offline GG
Re: pegging a VQ
« Reply #1 on: June 12, 2009, 02:05:21 PM »
It's just queuing to a VQ for the purposes of keeping a count.
As for the .A .GA .Q question - you could theoretically have a queue and agent group for instance both with the name "Support", so when you went to target or pull a stat it would look like:
Support@MyStatServer <----notice there is no way to differentiate which object i want.
the .<extension> allows the naming flexibility so I could:
Support@MyStatServer.GA <---pull stat or target a group of agents or virtual agent group
of
Support@MyStatServer.Q <--- pull stat or target a queue or virtual queue
Hope this helps
