" /> CTI integration through IVR - Genesys CTI User Forum
Author Topic: CTI integration through IVR  (Read 3841 times)
Kalpan
« on: June 09, 2009, 04:10:27 PM »
We have a Linux based IVR that needs to communicate with Genesys CTI to determine available agents before transferring a call. Which SDK should be used and where can I get the documentation? I am just starting out with Genesys so I am completely new to this.
Any push in the right direction will be helpful.
Thanks in advance!
Marked as best answer by on Today at 07:27:51 AM
Re: CTI integration through IVR
« Reply #1 on: June 11, 2009, 10:13:56 AM »
  • Undo Best Answer
  • Hi,
    Your question is general so it isn't easy to recommend you particular SDK. It seems that Statistics Platform SDK could make the work for you but... I would suggest you to contact Genesys sales representative to get details about available SDKs, pricing etc.
