Author Topic: Interaction Server can't connect to StatServer  (Read 5925 times)
« on: May 08, 2009, 11:30:28 PM »
My Interaction Server gives me:
18:09:58.597 Std 04502 Cannot connect to Datastream consumer (Stat Server) 'StatServerURS' at host 'genesys', port 8050, reason '[connect failed]'
I already enabled Java Extensions on that StatServer, the StatServer is Up...any ideas?
Re: Interaction Server can't connect to StatServer
« Reply #1 on: May 08, 2009, 11:31:48 PM »
Hum...but statserver returns:
2009-05-08 18:24:23> Client: Message 'DataStreamMessage'
'LONG_VALUE' 15
'TM_LENGTH' 0
'TM_SERVER' 1241825063
'USER_REQ_ID' 0
'REQ_ID' 1
2009-05-08 18:24:23> Client: Sending message to MCR_InteractionServer(1432)
Maybe it is ok??
Offline catanirex
« Reply #2 on: May 09, 2009, 08:41:53 AM »
do you have connections both between IxnSRv <-> SS AND SS <-> IxnSRv
« Reply #3 on: May 09, 2009, 04:39:23 PM »
Hi catarinex,
StatServer has in its connection tab to InteractionServer and InteractionServer has in its connections to StatServer.
Both are with addp configured. Very strange...
Offline fosterhw
« Reply #4 on: May 19, 2009, 07:59:03 PM »
I have the same error, running with primary and backup stat servers and IXN servers.  What was your solution?
« Reply #5 on: May 20, 2009, 01:44:55 AM »
I was using wrong StatServer...changed and problem got solved.
Offline steven33068
« Reply #6 on: April 28, 2016, 02:28:34 PM »
Hello Cavagnaro,
what did you mean exactly please? "I was using wrong StatServer...changed and problem got solved." did you upgrade to a different version? I am using 8.1 ixn with 8.5 SS. We see the exact same error.
Cannot connect to Datastream consumer (Stat Server) 'statserver_ccp_p' at host 'XXXX', port 3100, reason '[connect failed]'
Thanks Steve
« Reply #7 on: April 28, 2016, 02:57:50 PM »
Ummmm I was using another StatServer on the connections, I had like 3 different and made the configurations on the wrong one...  :-X
After realizing that it worked fine.
However, you should go by basic steps like verify if you can connect to TCP port on the remote server as the message is very generic and didn't make any sense at all or had any association with the error made
