Author Topic: Potential Bug in Config Server 5.1.5xxx  (Read 3347 times)
I am starting to run into a major problem with Config Server 5.1.51x that is really bothering me.
From time to time, depending on the config file, I was able to literally mess up the security definitions in CME. After booting the config server, if I would open an application and click on Securities/Permission then SOMETIMES I would see all the access groups in DUPLICATE. If I would try to add or remove an access group, it would tell me that I do not have enough access rights to do so, even though I was logged in as default! :(
I am enclosing a confserv.conf file that causes it.
PLEASE, DO NOT USE IT ON EXISTING CME DATABASE, BECAUSE I AM NOT SURE IF IT IS MESSING UP THE DATABASE OR NOT!
[confserv]
port = 12040
managementport =
server = dbserver_vic
verbose = 9
logfile ame = conf
logfilesize = 10240000
log emoveoldfiles = true
logcheckinterval = 60
loguffering = false
historylogkeep = 172800
historylogscan = 600
historylogsave= no
historylogmt= no
historylogfilesize=524288
historylogfile ame=./log/hist
dbcheck= false
[dbserver]
host = tom
port = 4040
dbengine = oracle
dbserver = ora816.tom
dbname = <required_except_for_oracle>
username = gen
password = gen
server =
reconnect imeout = 10
[dbserver_vic]
host = tom
port = 4040
dbengine = oracle
dbserver = ora81
username = vic
password = vic
server =
response imeout = 600
I cannot duplicate the problem ALL the time....
