Author Topic: Finding the number of active calls in a given queue via ActiveX  (Read 5789 times)
Offline sbc279
« on: February 25, 2009, 06:51:03 PM »
I'm trying to find the number of active calls using ActiveX in a particular queue (DN) that many extensions use.
I tried using TExtension11(Y).TQueryAddress(AddressInfoNumberOfAvailableAgentsInQueue), but always shows the correct number of available agents, agents logged in, but 0 for active calls.
Any suggestions?  Thanks
Re: Finding the number of active calls in a given queue via ActiveX
« Reply #1 on: February 25, 2009, 07:13:01 PM »
What do you mean by active calls? Calls in queue?
Offline sbc279
« Reply #2 on: February 25, 2009, 07:34:07 PM »
[quote author=cavagnaro link=topic=3902.msg16961#msg16961 date=1235589181]
Correct.  An agent may be on a call in "queue-2", for example.  I'd like to query that queue (or DN?) to see how many agents were on a call associated with it.
Do I have to query each analyst's DN, or is there an easier way?  What extension type should I register with for such queues? TypeDN? TypeACDgroup? TypeQueue?  I've tried them all.
« Reply #3 on: February 25, 2009, 08:01:16 PM »
?? That is imposible because the call has already been distributed from the queue to an agent extension.
Offline Adam G.
  • Still Gorgeous.......
« Reply #4 on: February 25, 2009, 08:39:35 PM »
It sounds like you're thinking in Avaya mode where a call is always in a 'queue' until the ACW is finished. In Genesys calls cease to be in a queue once they've been sent to an agent.
« Reply #5 on: February 28, 2009, 06:48:11 PM »
[quote author=sbc279 link=topic=3902.msg16960#msg16960 date=1235587863]
Ok, few very quick questions:
1. do you have calls actually queued in that queue or are they already distributed to agent? If latter, your count of 0 is corrent.
2. is it a VQ or actual ACD queue? If so, is it Avaya?
Offline sbc279
« Reply #6 on: March 12, 2009, 03:03:58 AM »
[quote author=victor link=topic=3902.msg17034#msg17034 date=1235846891]
Vic, Pavel is correct that I'm mixing Genesys vervbiage with CMS.  My apologies.
Yes, it is an actual ACD used with Avaya.  CMS calls them "Split/Skills"
