Author Topic: Difference in ucs psdk and AIL log....  (Read 4315 times)
Offline msanjayv
« on: October 17, 2008, 02:07:30 PM »
Hi
  I am sending outbound email with the help of UCS psdk. The code which I have used is
                InteractionAttributes interactionAttributes = new InteractionAttributes();
                interactionAttributes.TenantId = 101;
                interactionAttributes.MediaTypeId = "email";
                interactionAttributes.TypeId = "Outbound";
                interactionAttributes.SubtypeId = "OutboundNew";
                interactionAttributes.Status = new NullableStatuses(Statuses.Pending);
                interactionAttributes.Subject = "subject";
                interactionAttributes.QueueName = "Outbound queue";
                interactionAttributes.EntityTypeId = new NullableEntityTypes(EntityTypes.EmailOut);
                EmailOutEntityAttributes outAttributes = new EmailOutEntityAttributes();
                outAttributes.FromAddress = "a@a.com";
                outAttributes.ToAddresses = "b@b.com";
                InteractionContent content = new InteractionContent();
                content.Text = "message";
                RequestInsertInteraction insert = new RequestInsertInteraction();
                insert.InteractionAttributes = interactionAttributes;
                insert.EntityAttributes = outAttributes;
                insert.InteractionContent = content;
                IMessage response = UCSProtocol.Request(insert);
                If I use the above code, in the UCS log and the response, I could see the message as
              ucs.svc.protocol - Request (queued for 0 ms): Id=2|Type=Request|[b]Service=OMInteractions|Method=InsertInteraction[/b]|Parameters=[]|UserData=[]
ERROR 04:42:01,640 [SvcSrvW-1            ] <2> ucs.svc.protocol - No or invalid service name 'OMInteractions'
          But if I send the mail using  AIL in the log it apperars like
        [b] Service 'Contact' method 'findOrCreate'[/b] started, and the mail is sent successfully.
        Why is that the value of service is different between Interaction SDK  and platform SDK. I don't set the values for service and method anywhere. Is there anywhere I need to set the value of service and method.
Sanjay.
