" /> PreviewRecordRequest error - Genesys CTI User Forum
Author Topic: PreviewRecordRequest error  (Read 8979 times)
Offline dmans1
« on: October 03, 2008, 11:47:24 AM »
Hi
I am using the 7.2 ActiveX SDK to embed telephony functionality on our inhouse CRM programm.
The company has been using the 5.1 CTI version and we upgraded to 7.6 to implement the predictive dialing mode.
So far the preview mode was custom made through the CRM database using only the basic telephony events and commands(Tdial and so on).
We have managed to implement preview dialing and all the needed functionality through the api (addrecord recuests, predictive callbacks and so on) , but it seems that we are hiting the wall when trying to issue PreviewRecordRequest .
Sniffing trough the OCS logs that request is never actually registered and we receive only a eventACK from the Tserver.
Below is the sub implementing the request
[code]Public Sub PreviewRecordRequest(CampaignName As String)
    Dim MyUserData As TEventInfo
    Dim mypair As CTKVPair
    Dim myData As CTKVList
    Set MyUserData = New TEventInfo
    Set myData = New CTKVList
    myData.Clear
    Set mypair = New CTKVPair
    mypair.Key = "GSW_AGENT_REQ_TYPE"
    mypair.Type = CKVTypeString
    mypair.StringValue = "PreviewRecordRequest"
    myData.AddHead mypair
    mypair.Key = "GSW_APPLICATION_ID"
    mypair.Type = CKVTypeNum
    mypair.NumValue = GSW_APPLICATION_ID
    myData.Insert myData.GetCount + 1, mypair
    mypair.Key = "GSW_CAMPAIGN_NAME"
    mypair.StringValue = "Pilot_20080702"
    myData.AddTail mypair
    GenesysControls.my_Extension.TSendUserEvent MyUserData
End Sub[/code]
The above coding logic is used in every other request we make and works like a charm.
Any idea what might be wrong in this case? (FYI : Preview requests through the GAD web interface are working)
Re: PreviewRecordRequest error
« Reply #1 on: October 03, 2008, 08:23:58 PM »
Can you post the logs?
jjavierv
« Reply #2 on: October 03, 2008, 08:28:51 PM »
:-\ I hope this will help you... I have strange issues also with requests (including PreviewRecordRequest), throwing even an unnamed error coded 201.  The only thing I did after too many try outs was to send only StringValues, even for those supposed to be NumericValues.
« Reply #3 on: October 03, 2008, 08:57:33 PM »
logs?
Offline dmans1
« Reply #4 on: October 06, 2008, 07:30:14 AM »
ok... Event sequence as follows...
Dn registration, then agent logs in, gets events about the campaigns he's in and then he sents a preview record request and logs out.... That  preview request is nowhere to be seen in the logs.
Tserver logs
[code]message RequestRegisterAddress
AttributeThisDN '10304'
AttributeRegisterMode 0
AttributeControlMode 0
AttributeAddressType 1 (DN)
AttributeReferenceID 2
@09:42:56.7830 [0] 7.6.006.05 send_to_client: message EventRegistered
AttributeEventSequenceNumber 000000000038149c
AttributeCustomerID 'Resources'
AttributeTimeinuSecs 783000
AttributeTimeinSecs 1223275376 (09:42:56)
AttributeReason [2] 00 00..
AttributeExtensions [66] 00 03 01 00..
'AgentStatus' 0
'AgentStatusTimestamp' 0
'status' 0
message RequestAgentLogin
AttributeAgentID '1891'
AttributeAgentWorkMode 0 (Unknown)
AttributeReferenceID 3
@09:42:56.8290 [0] 7.6.006.05 distribute_response: message EventAgentLogin
AttributeExtensions [53] 00 01 00 00..
'AgentSessionID' 'CLBFBMDHKL7KP15TMLVV23O82C00J3GN'
AttributeEventSequenceNumber 000000000038149d
AttributeTimeinuSecs 829000
@09:42:56.8290 [0] 7.6.006.05 distribute_event: message EventAgentNotReady
AttributeEventSequenceNumber 000000000038149e
AttributeAgentWorkMode 4 (AuxWork)
@09:42:56.8290 [0] 7.6.006.05 send_to_client: message EventACK
AttributeEventSequenceNumber 000000000038149f
AttributeUserEvent RequestDistributeUserEvent
@09:42:56.8290 [0] 7.6.006.05 distribute_user_event: message EventUserEvent
AttributeEventSequenceNumber 00000000003814a0
AttributeUserEvent EventUserEvent
AttributeUserData [252] 00 07 00 00..
'GSW_CAMPAIGN_DESCRIPTION' ''
'GSW_CAMPAIGN_GROUP_DESCRIPTION' ''
'GSW_CAMPAIGN_GROUP_NAME' 'Pilot_20080702@PDS_Test_Outbound'
'GSW_CAMPAIGN_MODE' 'Preview'
'GSW_CAMPAIGN_NAME' 'Pilot_20080702'
'GSW_APPLICATION_ID' 129
'GSW_USER_EVENT' 'CampaignStarted'
@09:42:56.9230 [0] 7.6.006.05 send_to_client: message EventACK
AttributeEventSequenceNumber 00000000003814a1
AttributeTimeinuSecs 923000
@09:42:56.9230 [0] 7.6.006.05 distribute_user_event: message EventUserEvent
AttributeEventSequenceNumber 00000000003814a2
AttributeUserData [197] 00 06 00 00..
'GSW_CAMPAIGN_GROUP_NAME' 'Inbound'
'GSW_CAMPAIGN_NAME' 'Inbound'
'GSW_USER_EVENT' 'CampaignGroupAssigned'
@09:43:00.3920 [0] 7.6.006.05 send_to_client: message EventACK
AttributeEventSequenceNumber 00000000003814a8
AttributeTimeinuSecs 392000
AttributeTimeinSecs 1223275380 (09:43:00)
@09:43:00.3920 [0] 7.6.006.05 distribute_user_event: message EventUserEvent
AttributeEventSequenceNumber 00000000003814a9
message RequestAgentNotReady
AttributeReferenceID 4
message RequestAgentLogout
AttributeReferenceID 5
message RequestUnregisterAddress
AttributeReferenceID 6
@09:43:15.8610 [0] 7.6.006.05 send_to_client: message EventUnregistered
AttributeEventSequenceNumber 00000000003814c2
AttributeTimeinuSecs 861000
AttributeTimeinSecs 1223275395 (09:43:15)
@09:43:15.8610 [0] 7.6.006.05 distribute_response: message EventAgentNotReady
AttributeEventSequenceNumber 00000000003814c3
@09:43:15.9080 [0] 7.6.006.05 distribute_response: message EventAgentLogout
AttributeEventSequenceNumber 00000000003814c4
AttributeTimeinuSecs 908000
AttributeReferenceID 5[/code]
OCS logs
'AgentStatus' 0
'status' 0
'GSW_AGENT_ID' ''
'GSW_CALL_RESULT' 7
'GSW_TZ_NAME' 'EET'
'GSW_CONTACT_MEDIA_TYPE' 'voice'
'GSW_CALL_ATTEMPT_GUID' '84OBK6QF0P1HT7IFQ47B1AOIBO000CHR'
'RVQID' 'I5CK0IV8TT0EV3ENIKHUI1AF3O0027JT'
'RTargetTypeSelected' '2'[/code]
I have also sniffed the packets that are sent and arrived during the request
1st photo is the data sent on the request and the second is from the eventACK received data.
There's also a 3rd packet sent after that but that's the IP ack packet.
So.... any ideas? My guess till now is that the request is never sent from the pc
Edit: tried jjavierv's idea.. no luck
« Last Edit: October 06, 2008, 07:31:54 AM by dmans1 »
Offline Fra
« Reply #5 on: October 06, 2008, 10:27:32 AM »
if your OCS agent_preview_mode_start is set to yes\true, you must issue a PreviewDialingModeStart Request before any PrevieeRecordRequest.
Fra
Offline dmans1
« Reply #6 on: October 06, 2008, 10:40:57 AM »
I have done that also.
EventACK on previewdialingmodestart request and also on the previewdialingmodeove request
Offline Fra
« Reply #7 on: October 06, 2008, 10:52:00 AM »
Alright, I just didn't see it in the logs you posted.
« Reply #8 on: October 06, 2008, 03:36:02 PM »
One question, is your agent requesting Preview on NotReady mode??? Is this possible? For what I know agent must be on Ready status.
Offline dmans1
« Reply #9 on: October 07, 2008, 06:30:29 AM »
Standard procedure... we log on the agent in not ready mode  :)
Anyway, eventACK received even when the request is made while the agent is ready
« Last Edit: October 07, 2008, 09:15:37 AM by dmans1 »
« Reply #10 on: October 07, 2008, 03:31:47 PM »
Now you say that with GAD this works, right? If so I will go and compare what is the difference between GAD KVP and yours...
Offline dmans1
« Reply #11 on: October 24, 2008, 01:27:01 PM »
Its a duuuuhhhhhhhhhhhh case......
somewhere i te copy-paste proccess from a sub above in the code the
Set MyUserData.UserData = myData
part  before sending the request was somewhere lost, so i always kept sending an empty request...
(stupidity errors are always the most difficult to detect. :) )
