Author Topic: Agent Stuck in Agent Group  (Read 10379 times)
Offline makkerc
« on: July 25, 2008, 03:31:06 PM »
???Hi,
Part from bouncing the Stat Server Services, is there any way of clearing phantom users in CCP+? (7.5)
thanks in  advance,
Conor ;)
« Last Edit: July 25, 2008, 04:10:52 PM by makkerc »
Re: Agent Stuck in Queue
« Reply #1 on: July 25, 2008, 03:48:41 PM »
Agents or calls???
If calls:
http://www.sggu.com/smf/index.php/topic,1795.0.html
Search before posting please.
Offline makkerc
« Reply #2 on: July 25, 2008, 03:49:29 PM »
.. agents!!!
« Reply #3 on: July 25, 2008, 03:53:19 PM »
And how does an agent got stuck on a queue??? Can you explain better?
Offline makkerc
« Reply #4 on: July 25, 2008, 04:00:43 PM »
There is an Agent showing as logged into a queue but isn't logged in really.
He was moved out of this queue while still logged in.
Just need to know if there is a command to clear agents logged into a specific queue.
Thanks for the help!
« Reply #5 on: July 25, 2008, 04:03:29 PM »
Queue...Queue...agents on a queue....don't you mean Agent Group??? Or do you mean the queue where he was logged in?
Any way, the problem would be that your PBX never sent the logout event and StatServer still believes he is in there. What I'd do is log him again and then logout correctly.
Offline makkerc
« Reply #6 on: July 25, 2008, 04:10:15 PM »
Lol - cool
Yes an agent group.
We've tried logging him in  - didn't work.
Re: Agent Stuck in Agent Group
« Reply #7 on: July 25, 2008, 04:11:39 PM »
and your pbx what shows on his state?
Offline JGMG
« Reply #8 on: July 25, 2008, 11:42:06 PM »
Is this a voice PBX or something more exotic?
« Reply #9 on: July 28, 2008, 07:13:56 AM »
Well,
have you tried sending the logout command with ThisQueue, ThisDN, AgentID of the agent in question? Another, not so cool way of doing it (and means losing quite a lot of data would be to shutdown StatServer, delete ssbackup.000 file and restart your StarServer. But, then again, it is the dumbest way to do it, probably :(
Offline makkerc
« Reply #10 on: July 28, 2008, 08:50:29 AM »
[quote author=cavagnaro link=topic=3173.msg13021#msg13021 date=1217002299]
[/quote] Logged out
Offline makkerc
« Reply #11 on: July 28, 2008, 08:50:42 AM »
[quote author=JGMG link=topic=3173.msg13026#msg13026 date=1217029326]
[/quote] Voice only
Offline makkerc
« Reply #12 on: July 28, 2008, 08:58:23 AM »
[quote author=victor link=topic=3173.msg13034#msg13034 date=1217229236]
Well,
Cool, I was hoping someonewould pick his up.
I have just started with a Mobile Provider in dublin and they have been having this speradic issue for a while now; and the only way they have to clear this phantom agent is to restart the stat server, which, as you have noted, will result in the loss of stats for that day.
Could you direct me in how I am to use this "logout command with ThisQueue, ThisDN, AgentID"
Offline CTIgem
« Reply #13 on: July 28, 2008, 12:31:53 PM »
Use genesys softphone, I think you can download it from support site.
Once you get it, connect to tserver and register dn and change status that way it is back in sync.
Offline makkerc
« Reply #14 on: July 28, 2008, 04:01:28 PM »
[quote author=CTIgem link=topic=3173.msg13042#msg13042 date=1217248313]
[/quote] Cheers, and many thanks for your help - all
