" /> Connid incase of call transfer/conference - Genesys CTI User Forum
Author Topic: Connid incase of call transfer/conference  (Read 5272 times)
Gururaj S
« on: June 30, 2008, 07:45:41 AM »
I would like to know the maximum connids a call can have.
For ex: If a call is transferred to another agent or conferenced, will the connid of the call change? or will Tserver attach the same connid to the call?
Offline jbobinsk
Re: Connid incase of call transfer/conference
« Reply #1 on: July 07, 2008, 01:58:27 PM »
  • ConnID changes only in case of new leg of the call eg. consult connection. When the call is transferred Connid remain the same. Of course you have to monitor all the objects involved during call propagation in the switch - if not call after passing through such object call will be recognized as new one and you will get second ConnID.
    Regards
    jbobinsk
    gururaj s
    « Reply #2 on: July 08, 2008, 07:52:43 AM »
  • Hi jbobinsk,
    Thanks for your reply. I tested the same scenario and found that
    connid doesnot change incase of transfer or conference.
    Regards,
    Gururaj S
    Offline Dionysis
    « Reply #3 on: September 10, 2008, 02:07:55 PM »
  • If you look at the connid at the very beginning of the call and at the very end this is true.
    However.  Each leg of the call has it's own connid.
    So:
    External Call to Extension A
    connid:xxxx
    Extension A transfers to Extension B
    connid:yyyy
    transfer connid:xxxx
    Extension A leaves the call and External call is not to Extension B
    connid: xxxx
    So there are in fact 2 conn id's in the call (xxxx and yyyy in this case), but the original connid follows the original call until that leg is disconnected.
