" /> Why is my EventUser not being delivered correctly? - Genesys CTI User Forum
Author Topic: Why is my EventUser not being delivered correctly?  (Read 5282 times)
periscala
« on: June 26, 2008, 05:41:52 AM »
I am using Genesys SDK to connect to T-Server and exchange messages between agents using RequestUserEvent.
I see EventUserData but it is not being propagated to the client. Why, god, why?
10:56:18.075 Trc 04541 RequestDistributeUserEvent received from [440] (00000007  121.21.65.158:2973)
message RequestDistributeUserEvent
AttributeReferenceID 23
AttributeThisDN '3447'
AttributeUserData [23] 00 01 00 00..
'TestKey' 'TestValue'
AttributeCommunicationDN '3447'
10:56:18.075 Int 04543 Interaction message "RequestDistributeUserEvent" received from 440 ("")
@10:56:18.0750 [0] 7.5.009.00 send_to_client: message EventACK
AttributeEventSequenceNumber 000000000000009a
AttributeTimeinuSecs 75000
AttributeTimeinSecs 1214445378 (10:56:18)
AttributeUserEvent RequestDistributeUserEvent
10:56:18.075 Trc 04542 EventACK sent to [440] (00000007  121.21.65.158:2973)
@10:56:18.0750 [0] 7.5.009.00 distribute_user_event: message EventUserEvent
AttributeEventSequenceNumber 000000000000009b
AttributeUserEvent EventUserEvent
10:56:18.075 Trc 04542 EventUserEvent sent to [404] (00000004 StatServer 121.21.65.160:3743)
10:56:18.075 Trc 04542 EventUserEvent sent to [392] (00000003 RoutingStatServer 121.21.65.160:3742)
10:56:18.075 Trc 04542 EventUserEvent sent to [372] (00000002 OCS 121.21.65.160:3741)
Where is sent to [XXX (My Client))?
And yes, I have registered 3447:
16:47:20.527 Trc 04541 RequestRegisterAddress received from [440] (0000003e  121.21.65.158:2973)
message RequestRegisterAddress
AttributeRegisterMode 0
AttributeControlMode 0
AttributeAddressType 1 (DN)
AttributeReferenceID 9
(tservice_proc) ControlMode set to 1 for 3105
@16:47:20.5270 [gctmi] Distributing request RequestRegisterAddress
@16:47:20.5270 [tsgctm] Address [3447,tDN,sIDLE] reqRegisterAddress
@16:47:20.5270 [gctmi] request RequestRegisterAddress removed from reqMgr
@16:47:20.5270 [0] 7.5.009.00 send_to_client: message EventRegistered
AttributeEventSequenceNumber 00000000000010fe
AttributeTimeinuSecs 527000
AttributeTimeinSecs 1214293640 (16:47:20)
AttributeExtensions [144] 00 07 01 00..
'AgentStatus' 3
'queue-1' '4871'
'AgentStatusTimestamp' 1214293278
'AgentLoginTimestamp' 1214293278
'AgentWorkMode' 4
'mwl' 0
'status' 0
AttributeAgentID '5173'
16:47:20.527 Trc 04542 EventRegistered sent to [440] (0000003e  121.21.65.158:2973)
Re: Why is my EventUser not being delivered correctly?
« Reply #1 on: June 26, 2008, 07:03:45 AM »
  • Ok,
    first of all, it seems like both of your clients use the same connection to T-Server:
    16:47:20.527 Trc 04542 EventRegistered sent to [440] (0000003e  121.21.65.158:2973).
    Are you by any chance using our GAS Server? Looking through the log, it seems like our GAS Server framework based on platform SDK. Am I right? If so, you cannot get the event back, because both of your clients are behind GAS, thus
    Genesys T-Server would not return Event to it, because that connection is seen as originator of the request, thus only Ack would be returned to it.
    I wonder if there is a different way to do it. Let me see what is going on.
    periscala
    « Reply #2 on: June 26, 2008, 08:24:23 AM »
  • Hi, Vic,
    you are right, we are using STAR's GAS 1.0 with Platform SDK. I wanted to modify the functionality so we would get the messages that agents send to each other inside tserver logs, by modify userEvent to issue RequestDistributeUserEvent.
    PP
    « Reply #3 on: June 27, 2008, 07:26:24 AM »
  • Hey,
    I actually know who you are :)
    Well, it would not work; however, it should be fine, because GAS would not only issue a message to T-Server but actually if it determines that the other user is on the same GAS server, it will also forward the event directly to that user as well. I like your concept of adding RequestDistributeUserEvent because it means you could then exchange messages between two separate GAS servers. I think we should add it as default. Very nice thinking!
