Author Topic: Parse tool - Throwing exceptions when testing grammar files  (Read 4680 times)
Anjan
I do see a parseTool out in the bin folder. When I am trying to test a grammar file using the following command for some reason it is throwing some errors instead of validating the grammar file. Please help.
C:\Program Files\SpeechWorks\OpenSpeech Recognizer\bin>parseTool -t_s c:\temp\prov.grxml
Jun 16 16:17:55.40| 7256|||| ** ERROR => SVC AFFECT **| 27100|  SWIREC| SWIrec API| SWIrecInit | SWIrecAPI_stubs: Exception in function.
cbabe066
I see you used the -t_s switch.  Did you input a test sentence?  If that was not your intention, drop the -t_s switch and try it again.
Edgar Leon
Re: Parse tool - Throwing exceptions when testing grammar files
« Reply #2 on: October 16, 2009, 04:22:03 PM »
  • Hello, did you find the solution to this?
    I'm facing the same problem and I don't seem to be able to get the source of the problem...
