Author Topic: Convert string to integer (IRD)  (Read 4658 times)
Gitanjali
« on: June 12, 2008, 01:43:54 PM »
Plz specify the Interaction routing designer function for converting string to integer .
Thanks in advance
Marked as best answer by on November 14, 2024, 10:24:26 PM
Offline jbobinsk
Re: Convert string to integer (IRD)
« Reply #1 on: June 12, 2008, 02:24:28 PM »
  • Undo Best Answer
  • As I remember - if you have string eg '123abc' and assign it to number variable directly you will get 123 value.
    Regards
    jbobinsk
