Author Topic: E-mail -Media Type in genesys  (Read 5628 times)
Gitanjali
« on: May 30, 2008, 07:27:48 AM »
Hi all,
we are trying to develop an email client in Genesys Demosrv. first we are establishing connection with Ixn Server(Interaction server) .when we add the media type email as a key value collection -for second parameter it is expecting an object in the following statement  "medialist.addObject("email",0)"  can u plz suggest and provide a solution for adding the media type.
code snippet
public boolean requestLogin(String strAgentId, String strPlaceid,
IxnSrvConnect ixnSrvConnect){
try{
KeyValueCollection medialist = new KeyValueCollection();
  [color=red] medialist.addObject("email",0);[/color]
    InteractionServerProtocol inxProtocol = ixnSrvConnect.getinxProtocol();
RequestAgentLogin requestLogin =
            RequestAgentLogin.create(101, strPlaceid, ReasonInfo.create());
requestLogin.setAgentId(strAgentId);
    requestLogin.setMediaList(medialist);
Message message = inxProtocol.request(requestLogin);
if(message.messageId()== EventError.ID)
return false;
}catch(Exception e){
e.printStackTrace();
Thanks in advance
Marked as best answer by on Today at 11:02:03 AM
Offline mhsrinivasan
Re: E-mail -Media Type in genesys
« Reply #1 on: April 17, 2009, 10:59:54 AM »
  • Undo Best Answer
  • Probably, you need to check the Configuration Server
    + Resources
      + Business Attributes
          + Media Type
            + Attribute Values
    Check whether email is there?
    You can add the media list from there.
    Offline YevgeniyP
    « Reply #2 on: April 19, 2009, 07:10:29 AM »
    see code sample from DevZone
