Author Topic: SIP Server Connection for Agents Behind NAT  (Read 15412 times)
Offline hendro
« on: March 05, 2008, 06:58:24 AM »
Dear all,
We are trying to connect to the Genesys SIP Server from the client that is behind NAT Network.
But we are unable to hear the sound, I have google it and found that we need a NAT Traversal inside our sip server.
Could anyone help us about how to configure the Genesys SIP Server, to able to communicate with the clients.
Thank you very much,
Best Regards,
Hendro
Re: SIP Server Connection for Agents Behind NAT
« Reply #1 on: March 06, 2008, 11:20:25 AM »
Hendro,
Genesys SIP Server doesn't support NAT Traversal in current version. You need third-party SIP/RTP proxy or establishing a VPN connection between endpoint and SIP Server.
René
Offline Genesys CTI Forum Administration Team
« Reply #2 on: March 07, 2008, 01:42:23 AM »
Oh, boy, this one is giving me a real pain. All I could come up with was:
1. use VPN
2. NAT transversal
3. if you are using RTC and you have your own code, you can add a function to allow you to do this, but it needs some major programming and head scratching since MS no longer supports it.
Best regards,
Offline hendro
« Reply #3 on: March 10, 2008, 03:53:23 AM »
Dear vic and René,
Thank you very much for your answer,
I also just got the same answer from the support. And it looks like we need to use the third party NAT transversal.
Could you advise any recommended products for this NAT transversal solution?, I mean the genesys compatible or tested one.
Really appreciate your help
Best Regards,
Hendro
« Reply #4 on: March 16, 2008, 09:35:33 PM »
Hendro,
It isn't easy to suggest you some products without knowledge of your environment. Please check the links below for information of some products/solutions that provides NAT Traversal functionality:
General info
- http://www.voip-info.org/wiki/index.php?page=NAT+and+VOIP
Free / OpenSource / GPL
- OpenSER (http://www.openser.org/)
- SIP Express Router (http://www.iptel.org/ser/)
- YATE (http://yate.null.ro/pmwiki/)
- Asterisk (http://www.asterisk.org/)
Commercial
- AcmePacket (http://www.acmepacket.com)
- Cisco (http://www.cisco.com)
Hope it helps you
René
Offline hendro
« Reply #5 on: March 17, 2008, 05:09:38 AM »
Hi René,
Thank you very much for your kind response,
I have tried to download and use the sip proxy, but still won't connect to the genesys server.
Is there any setting that I need to config inside the Genesys T-Server SIP to use  the sip proxy.
Best Regards,
Hendro
« Reply #6 on: March 17, 2008, 08:19:21 PM »
Hi Hendro,
I have to repeat myself again that it isn't easy to answer your question without knowledge of your environment. Generally, there is no need to configure anything on SIP Server side when using SIP Proxy in NAT Traversal mode. In fact NAT Traversal proxy should be invisible for any SIP party as it "only" translates the IP addresses in SIP headers.
Could you post here more information about your environment or some logs? Are you able to connect SIP Server and establish a call using SIP client on the same network subnet = no firewall/proxy etc. between SIP Server and the client?
René
« Reply #7 on: March 17, 2008, 08:57:16 PM »
Hi hendro,
Usually this implementations are done by someone who has experience with this issue as Renč said, it is hard to help without being at the site. Maybe you was assigned to this mission and have no idea on how SIP works, I believe we can help until some point. Reading and documenting yourself is the best way for you to solve your issues.
Here is a good introduction adding to the resources Renč gave to you:
http://freshmeat.net/articles/view/2079/ For you to understand the problem you are facing and the cause of it
http://en.wikipedia.org/wiki/NAT_traversal General info on how this works.
Unfortunatelly if you doesn't have some basic network skills it will be hard to help you
The best way in this case will be maybe to contact Genesys and ask for direct support as they may have already face this issue.
Offline hendro
« Reply #8 on: March 23, 2008, 06:23:49 PM »
Dear Cavagnaro, Vic, René
Thank you very much for your kindly help,
Really appreciate all the information you posted.
I am still trying to do the connection and hopefully we can make it.
Once again, thank you and success for all of you
thanks,
Best Regards,
Hendro ;D ;D
Offline Gulden_NL
    • VoxPeritus - The Voice of Experience
Re: xYQyKFGwwSSiewznWT
« Reply #9 on: October 27, 2009, 02:02:39 PM »
[quote author=Maxx54 link=topic=2834.msg21479#msg21479 date=1256241675]
Trip is injected with 40mg of mirazine by Phlox to cut the decompression time in half to three hours. ,
Timothy Leary is alive and still tripping!  ;D
I agree with Rene' and Vic, need a lot more info before recommending anything.
Having said that, Genesys pretty much is clueless about anything Cisco, but does have some internal experience with AcmePacket. And forget any help with anything Open Source.
