" /> Does anyone know how to set parameter to userData in RequestUpdateUserData ? - Genesys CTI User Forum
Author Topic: Does anyone know how to set parameter to userData in RequestUpdateUserData ?  (Read 5400 times)
nui
Now, I am trying to make simple softphone using .net sdk with c#.net and I think I also need to attach data from my program but I am did not know how to set parameber into userData(KeyValueCollection ) and does .net sdk support this or not ?
below is some neccessary and source code :
using Genesyslab.Platform.Voice.Protocols.TServer.Requests.Userdata;
using Genesyslab.Platform.Commons.Collections;
Does reference is enough for coding ?
public static bool UserAttachData(TServerProtocol protocol)
            IMessage response;
            try
                KeyValueCollection userData=null; <<< If I need to set key = "test", values="FirstTime" , Do you know how to set it to userData ?
                RequestUpdateUserData reqUpdateuserData = RequestUpdateUserData.Create(
        thisDN,
        connId,
        userData
                response = protocol.Request(reqUpdateuserData);
                Debug.Print(response.ToString());
                return true;
            catch (Exception e)
                return false;
Please give me suggestions, I am very new with genesys, just start learning basic concept.
Nui
Try this piece of code:
[code]KeyValueCollection userData= new KeyValueCollection();
userData.Add("key","value");
[/code]
The method Add has several overloads. Please check Platform SDK documentation for more information.
René
nui
Thank you , René for your code
I did not realize about it.  ;D
