" /> Any online training on genesys gplus adapter integration with SAP CRM? - Genesys CTI User Forum
Author Topic: Any online training on genesys gplus adapter integration with SAP CRM?  (Read 7744 times)
vinod
Hi All-
PLease let me know if there are
« Last Edit: November 29, 2007, 10:47:15 AM by victor »
Vinod
Re: Any online training on genesys gplus adapter integration with SAP CRM?
« Reply #1 on: November 30, 2007, 01:43:16 PM »
Can someone please help me to get this info
« Reply #2 on: November 30, 2007, 03:06:02 PM »
No online training, reading the deployment guide and following the steps should be enought, i didi it once and was not hard with a SAP guy beside me.
Marked as best answer by on June 01, 2019, 04:49:50 PM
vinodgujja
« Reply #3 on: December 04, 2007, 04:05:23 AM »
Thanks a lot sir,
I am following the deployment guide, everything on genesys side went fine, But we are not sure what configurations Should be done at SAP side. Please forward me if you have any docs related to SAP configuration on vinoodgujja@gmail.com.
Thanks once again.
« Reply #4 on: December 04, 2007, 04:21:57 AM »
On SAP side they should only configure their objects, maybe if you give them the Genesys guide they will understand what has to be done.
Offline Karla Patricia
« Reply #5 on: September 26, 2016, 01:05:34 PM »
You can do this with Tenfold, a third-party connector. Our software integrates SAP CRM with major telephone systems like Genesys.
To connect, check out this page: https://www.tenfold.com/integrations/sap/genesys
[quote author=vinod link=topic=2617.msg10235#msg10235 date=1196320168]
Hi All-
« Reply #6 on: September 26, 2016, 05:34:50 PM »
Ok...stop promoting your pro here. Read the forum rules.
