" /> ActiveX Toolkit - Genesys CTI User Forum
Author Topic: ActiveX Toolkit  (Read 17678 times)
Offline sy278
ActiveX Toolkit
« on: October 15, 2007, 09:31:09 AM »
Hi Guys,
Where do you get the ActiveX toolkit and how much does it cost?
Re: ActiveX Toolkit
« Reply #1 on: October 15, 2007, 01:44:16 PM »
It's on the Framework CD (at least on versions 7.0 and 7.1). It has no cost to get it as it's "free" to use with your TServer...however on the real world there are limitations on what you can do, not technical but $$$ licenses...
Offline sy278
Re: ActiveX Toolkit
« Reply #2 on: October 17, 2007, 02:45:42 PM »
thanks for that Cav, our VAr is trying to charge us £30k for it.
Re: ActiveX Toolkit
« Reply #3 on: October 17, 2007, 03:59:34 PM »
? Why? I can send you the VB/Java toolkit if you want...
jjavierv
Re: ActiveX Toolkit
« Reply #4 on: January 02, 2008, 10:38:44 PM »
We have here Genesys 7.1, obviously it came with the ActiveX toolkit... can I use and get the .net Toolkit?
And also, am I dreaming if I want to make a Asp.Net based softphone using Genesys .Net components?
Re: ActiveX Toolkit
« Reply #5 on: January 02, 2008, 10:56:52 PM »
well the purpose of the TLib components is for you to make your own softphone on Java, VB, .NET, etc.
However I believe now that .NET Toolkit is licensed as it must work by hand with another Genesys component called GIS.
Please correct me if I'm wrong as I'm trying to understand the new licensing architecture.
Offline Daimonas
  • There's a fish in every bowl.
Re: ActiveX Toolkit
« Reply #6 on: January 03, 2008, 02:25:45 PM »
Yes, there have been a lot of changes in the Genesys licenses. Essentially, they provide development kits with a wider range of access to the internal application code. With this however, they changed their license and cost structure.
For the most part, if you have the Universal license kit from 6.5x, you are given the "right to use" all the SDKs for 7.x, including the .NET platform. For licenses however they have split them up into two categories: Developer licenses to "develop" on the SDK and connecter licenses for the end-user to "use" the completed application.
If you visit DevZone, they have a few webinars explaining the whole process, even though it’s past the date for signup, you can still sign up and receive a link where to connect to the webinar and watch the recorded version.
For pricing, contact your Genesys Sales Rep for details.
« Last Edit: January 03, 2008, 02:29:40 PM by Daimonas »
Noor Quadri
Connecting to STAT Server Internal Application
« Reply #7 on: February 12, 2008, 05:34:16 PM »
Would like to know Genesys pricing in the following solution design
I am connecting to STAT server through GIS. One connection that pulls some stats out and publishes those stats on company website accessed by over 1000 users.
Please reply at my email address above
Regards
Re: ActiveX Toolkit
« Reply #8 on: February 12, 2008, 06:33:51 PM »
? We are not Genesys sales department. Ask your Genesys saler or contact them directly. www.genesyslab.com
Re: ActiveX Toolkit
« Reply #9 on: February 12, 2008, 07:01:36 PM »
I fully agree with Cavagnaro that nobody here is able to tell you pricing information. However, I have an advice for you - to achieve described functionality you need "Advanced Integration Connector" or "Wallboard connector".
- Advanced Integration Connector is licensed per seat
- Wallboard Connector is licensed per site. There is one important limitation - it isn't allowed to broadcast collected statistics directly to agents' desktop using that license.
Hope it helps you
René
Noo Quadri
Advanced Agent Connector
« Reply #10 on: February 12, 2008, 07:14:37 PM »
I understand we need advanced agent connector and the pricing is for Genesys to quote. But if you are publishing onthe web for million users, do we need so many connectors. In the Architecture there is one access to STAT Server through GIS/SDK only and data is not displayed on agent work station but the general public on the web
Would be interesting to know if any one has done this sort of thing!!!!!
Re: ActiveX Toolkit
« Reply #11 on: February 12, 2008, 07:24:18 PM »
Hum..your development will write only to one http server or one http server will request to your development the stats from Statserver. No matter how many times (users) pull the info, the gateway is still only one http server. If you have multiple http servers for load balance or redundancy then it is an extra connector for those. You can have a billion users but as only one http server doing the request I see no problem.
Re: ActiveX Toolkit
« Reply #12 on: February 12, 2008, 07:30:41 PM »
As I have written in my previous post Advanced Integration Connector (AIC) is licensed per seat. It means that you have to buy the same amount of AIC licenses as you have places used by the agents. Genesys has no 'per-user' or 'concurrent users' licenses.
I would say that "Wallboard Connector" license could be sufficient for your purposes but Genesys could have a different opinion.
Noor Quadri
Re: ActiveX Toolkit
« Reply #13 on: February 12, 2008, 07:38:32 PM »
Yes Genesys is saying we need to pay for web licences too (Per user access) although Genesys is not assisting us to connect to the Web and as a matter of fact I should pay for only one connection.
This  is a multi million dollar solution for a simple requirement. If I put some stats on CCN Web , Genesys stock price will sky rocket as there are over a billion people access CNN site this will be sort of highway robery
Re: ActiveX Toolkit
« Reply #14 on: February 12, 2008, 07:42:34 PM »
Makes no sense.... ???
Wouldn't they mean per agent or object monitored?
It is ridiculous that they want to charge to per web page visitor...how can they discrimine it? On a low day you can have 10 visitors all day and no concurrent. On a heavy day you can have 10000 visitors and only 2 concurrent.
Can Genesys explain how they know how many visitors are on your site? what happens if you say only 1? 5? 10? How can they verify? Which support will you receive from them with this licensing?
