Author Topic: Question using TKeyPad1 to check Voice Mail  (Read 6432 times)
Offline vivek
« on: September 18, 2007, 05:17:29 PM »
Hi, I am using TKeyPad1 in my softphone for basic call functions.
I have an issue, after agent dialed Voice mail number to check his messages, he needs enter his password in TKeyPad1, then it should go to switch and reterive his messages.
I am not sure how to send the password to switch using TKeyPad1. If anyone had a sample pice of code please post it here.
Thanks a lot.
Re: Question using TKeyPad1 to check Voice Mail
« Reply #1 on: September 21, 2007, 03:40:14 PM »
Never used TKeyPad... but from what I understand it just collects digits, right? And then you just send them via TExtension. I guess there is an event when user presses a key on keypad and thiws is when you react to it?
Offline vivek
« Reply #2 on: October 01, 2007, 01:02:19 PM »
I tried user press event, but no luck.
« Reply #3 on: October 01, 2007, 05:31:02 PM »
Try this:
TLine1.TSendDTMF TKeyPad1.KeyPadText
Offline vivek
« Reply #4 on: October 07, 2007, 07:17:31 PM »
Cavagnaro - TLine1.TSendDTMF TKeyPad1.KeyPadText is working. Thanks.
hari
« Reply #5 on: February 02, 2009, 07:49:45 AM »
Hi, I use TkeyPad1 in new form, but appear as disable?
« Reply #6 on: February 03, 2009, 02:45:15 AM »
is it associated with textension?
hari
« Reply #7 on: February 03, 2009, 05:38:29 AM »
[quote author=cavagnaro link=topic=2475.msg16364#msg16364 date=1233629115]
Hi, how do I can assosiated this Tkeypad1 with TExtension in my new form?
hari
« Reply #8 on: February 03, 2009, 05:44:09 AM »
[quote author=hari link=topic=2475.msg16370#msg16370 date=1233639509]
sorry, I Plan this for send an Extension number for an office call[quote author=hari link=topic=2475.msg16370#msg16370 date=1233639509]
