Author Topic: Querying StatServer (Java)  (Read 5202 times)
Offline Ali
  • Haunted by Genesys
    • My Web Site
« on: September 15, 2007, 10:34:27 PM »
[b]Warning:[/b]
[font=Verdana][color=navy]To be able to use the following code, you need to have valid Genesys license for related libraries. What you will find below is given here for experimental purposes.[/color][/font]
[size=10pt][b]Introduction[/b][/size]
As you know, retrieving real-time data from StatServer requires an additional product. Well, if you want to implement a stand-alone service that queries StatServer for current-, average-, total-, or stat-related data, then you need to use Stat Server Java libraries.
Plus, please keep in your mind that I am not here to reveal Genesys secrets. These libraries are open. What you need is to have a related Genesys license for development.
This entry focuses on how to query StatServer using related Java libraries. Here, what you have found are some code snippets.
[b]Libraries[/b]
There exist two main Genesys libraries:
[color=green]icom.genesyslab.statistics.lib.*;
Genesys.ComLib.TKV.TKVList;[/color]
You need to declare them beforehand.
[b]Arguments[/b]
1. Hostname or IP address of the StatServer
2. Port of the StatServer
3. Name of the tenant (e.g., "Resources")
4. Object_Type:
0 --> Agent
1 --> Place
2 --> RegDN
3 --> Queue
4 --> Routing Point
5 --> Group Agents
6 --> Group Places
5. Object_ID (e.g., "Agent_5610", "CreditCards", and etc.)
6. StatType (e.g., "CurrNumberNotReadyStatuses")
7. Subject (int)
8. Category (int)
9. Notification Mode (int)
10. Main Mask (BitMap)
11. Rel(ative) Mask (BitMap)
Declaration:
[code]public static String SS_hostname;
public static String SS_port;
public static String SS_tenant="Resources"; // "Resources is the default"
public static int SS_objectType;
public static String SS_objectID;
public static String SS_statType;
public static int SS_subject;
public static int SS_category;
public static int SS_notificationMode=1; // 1 is the default
public static String SS_mainMask;
public static String SS_relMask;
public static String Hostname;
    public static int Port;
    public static String GUID;[/code]
[b]Connecting StatServer[/b]
[code]QueryStatServer statlibtest = new QueryStatServer();
        // Connect to the given Stat Server:
        int rx;
        rx=(int)(Math.random()*100);
        // 0x1122f
        int chk = statlib.SOpenServerEx(SS_hostname, SS_port, null, "Stn666", rx, statlibtest, 0); [/code]
Where,
[i]SOpenServerEx[/i] is used to get connected to the given statServer.
Once you have connected, you should notify StatServer with your tenant profile:
[code]STenantProfile stenantprofile = new STenantProfile(SS_tenant, "");
        int j = statlib.SSetNextTenantProfile(stenantprofile);
        SRequestParams srequestparams = getStatRequest();[/code]
[b]Querying StatServer[/b]
At first, initialize KVList (assuming that you all know what the heck KVPair/KVList is):
[code]TKVList tkvlist = new TKVList();
        tkvlist.TKVListAddString("value", "A");[/code]
Well, let's query StatServer, for example, [color=blue]TotalLoginTime[/color],
[code]statlib.SLOpenStat(SS_objectType, SS_objectID, SS_statType, tkvlist, 0, 0);
        int k = statlib.SOpenStat(srequestparams);[/code]
Where,
    [code]public static SRequestParams [b]getStatRequest[/b]()
    int num;
    int i,n=0;
    String dummy;
        SRequestParams srequestparams = new SRequestParams();
        srequestparams.objectID = SS_objectID;
        srequestparams.objectType = SS_objectType;
        srequestparams.subject = SS_subject;
        srequestparams.category = SS_category;
        srequestparams.notificationMode = 1; //SS_notificationMode;
        // Configuration
        srequestparams.tmNotificationFrequency = 3;
        //srequestparams.insensitivityPercentage = 90;
        // Setting the Main Mask
        SActionsMask sactionsmask = new SActionsMask();
        // Here, we have to check out the first two bytes
        // of the given hash -- it gives us the number of
        // bytes to be set.
        // If the first two bytes = "00", then it means CLEAR ALL
        // If the first two bytes = "FF", then it means SET ALL
        // If the numerical value of the first two bytes <0,
        // then set ALL except the given
        // If the numerical value of the first two bytes >0,
        // then set the given bits only.
        // With the light of this knowledge,
        dummy=SS_mainMask.substring(0, 2);
        sactionsmask.clearAll(); // First clear the bitmap
        if (dummy.equalsIgnoreCase("FF"))
        sactionsmask.setAll(); // Set all bits
        else if (dummy.equalsIgnoreCase("00"))
        dummy="kek";// Nope
        else
        num=Integer.parseInt(dummy);
        // just set the given bits
        if(num>0)
        n=0;
        for(i=0;i<num;i++)
        n=n+2;
        sactionsmask.setBit(Integer.parseInt(SS_mainMask.substring(n, n+2)));
        else
        // set all except the given
        // e.g., in CME, "*, ~CallOutbound, ~WaitForVic"
        n=0;
        for(i=0;i<num;i++)
        n=n+2;
        sactionsmask.clearBit(Integer.parseInt(SS_mainMask.substring(n, n+2)));
        srequestparams.MainActionsMask = sactionsmask.getBytes();
        // Setting the Relative (Rel) Mask:
        srequestparams.interval = 0;
        srequestparams.tmLength = 10;
        SActionsMask sactionsmask1 = new SActionsMask();
        dummy=SS_relMask.substring(0, 2);
        sactionsmask1.setAll(); // Set all bits
        sactionsmask1.clearAll(); // First clear the bitmap
        else if (dummy.equalsIgnoreCase("DN"))
        dummy="kedi";// Do Nothing!!!
        else
        // just set the given bits:
        if(num>0)
        n=0;
        for(i=0;i<num;i++)
        n=n+2;
        sactionsmask1.setBit(Integer.parseInt(SS_mainMask.substring(n, n+2)));
        else
        n=0;
        for(i=0;i<num;i++)
        n=n+2;
        sactionsmask1.clearBit(Integer.parseInt(SS_mainMask.substring(n, n+2)));
        srequestparams.RelActionsMask = sactionsmask1.getBytes();
        return srequestparams;
    }[/code]
Nice, eh?  ;D
Cheers,
Ali
[b]P.S.[/b] What given above belongs to former versions of Genesys Framework. Well, it might not work with current versions. On the other hand, here, my aim is to give you a clue about Genesys-programming.
« Last Edit: September 17, 2007, 06:04:22 PM by victor »
Re: Querying StatServer (Java)
« Reply #1 on: September 16, 2007, 05:55:58 AM »
Yeah! Very but very nice!
