Author Topic: addp settings and its logging  (Read 8160 times)
minoru
« on: August 14, 2007, 04:07:37 AM »
Hi!
I can't figure out how to show addp logging in using platform SDK.
Here is how I set it up:
PropertyConfiguration propertyCfg = new PropertyConfiguration();
    propertyCfg.SetOption("protocol", "addp");
    propertyCfg.SetOption("addp-timeout", "5");
    propertyCfg.SetOption("addp-remote-timeout", "10");
    propertyCfg.SetOption("addp-trace", "both");
    tserverProtocol.Configuration = propertyCfg;
    tserverProtocol.Open();
I see addp trace in T-server logs, but what do I need to do to see addp trace inside my program?
I heard that there is a Log property for tserverProtocol object, but I cannot find it. tserverProtocol.Log does not exist! :-\
Where is .Log property and how do I use it?
M.
Re: addp settings and its logging
« Reply #1 on: August 16, 2007, 07:45:41 AM »
  • Hi, Minoru,
    as far as I know, there is no way to log addp trace in Java SDK 7.2 . I am praying they will add it in later releases of 7.5.xxxx .
    What I do find bewildering is that what is the point of addp's "number-attempts" and "reconnect-timeout", if addp's timeout forces SDK protocol to issue a disconnect and it is up to a client to try to reconnect.
    How does addp-reconnect, number-attempts work in Java SDK?
    Offline bublepaw
    « Reply #2 on: August 16, 2007, 08:03:54 AM »
  • Hi, Minoru,
    There is method called EnableLogging(ILogger). Using this method You can have access to interal library logging. I've checked it - there 2 messages for addp:
    Addp packet received: p
    Addp packet received: P
    I hope it helps. ( I've checked in .Net 7.2 SDK so it should work in 7.5 )
    Paul
    Offline bublepaw
    « Reply #3 on: August 16, 2007, 10:18:52 AM »
  • Hi,
    I little update - in 7.5 ILogger interface was changed and message about addp additionaly contains server address and port.
    Paul
    « Reply #4 on: September 03, 2007, 06:47:12 AM »
  • [quote author=bublepaw link=topic=2413.msg9077#msg9077 date=1187251434]
    Hi, Minoru,
    Paul
    Bubblepaw,
    Judging by Minoru's code, it seems to be Java.  I could bet there was no such a function for Platform SDK for Java in 7.2!  :-\
