" /> CC Pulse Action Item Sending Email - Genesys CTI User Forum
Author Topic: CC Pulse Action Item Sending Email  (Read 11554 times)
prashanth
« on: June 13, 2007, 02:04:11 AM »
Hi Guys
I am trying to use Send Email Action Item from Action Wizard along with a Threshold.Already in CCpulse we have SendEmailwithCDO.It is using my outlook express to send the email and everytime when it asks me with message box R u sure u want to send Email.I dont want that everytime i click on Yes to send Email. I want that it should automatically send a Email when ever that threshold is met without prompting me.
I want that that email should be send to multiple email addresses.Can u guys send me VB script coding to send email to multiple Recepitients.
Help Me OUT
Offline CTIgem
Re: CC Pulse Action Item Sending Email
« Reply #1 on: June 14, 2007, 12:15:52 PM »
  • I just worked on this.
    Use vbSendmail, search on yahoo, you'll hit the link.
    Offline mark
    « Reply #2 on: August 30, 2007, 02:21:36 PM »
  • I might be being a muppet (more than likely!), but can you give me more info on using vbsendmail for ccpulse actions. Would like to use it!
    Mark
    Offline CTIgem
    « Reply #3 on: September 04, 2007, 08:06:47 PM »
  • Here you go...
    Set poSendMail = CreateObject("vbSendMail.clsSendMail")
              poSendMail.SMTPHost = "your snmp server goes here"
              poSendMail.From = "your from addr"
              poSendMail.FromDisplayName = "whatever"
              poSendMail.Recipient = "list of people's addr"
              poSendMail.RecipientDisplayName = "whatever"
              poSendMail.ReplyToAddress = ""
              poSendMail.Subject = "Alarm notification from CCPulse"
              poSendMail.Attachment = ""
              poSendMail.Message = "Calls are waiting in the Queue"
              poSendMail.Send
              Set poSendMail = Nothing
    BTW, I just implmented with JavaMail becauses security concerns with VbsendMail.
    Offline mark
    « Reply #4 on: September 05, 2007, 07:41:26 AM »
  • Thanks, getting an activeX error regarding creating object vbSendMail.clsSendMail.
    I have registered the .dll
    Mark
    Offline mark
    « Reply #5 on: September 05, 2007, 08:08:22 AM »
  • Yes, I was being a muppet, completely fogetting that the dll and mswinsck.ocx needed to be registered on the citrix server that ccpulse was being delivered by!
    Which reminds me, really need to install locally!
    Visitor319
    Overview
    « Reply #6 on: September 26, 2007, 10:45:10 PM »
  • I have visited your site 934-times
    Visitor453
    Overview
    « Reply #7 on: September 26, 2007, 10:46:39 PM »
  • I have visited your site 136-times
    Offline S
    CC Pulse Action Item - Sending Email
    « Reply #8 on: September 03, 2008, 07:47:06 PM »
  • Did anyone try this on 7.2 above versions or even with javamail? please share it with me.
