Done it!!
USER EVENT HANDLING SUB
[code]Private Sub Connection1_TEventUserEvent(EventInfo As DesktopToolkitX.TEventInfo)
    Dim i As Integer
    If EventInfo.UserData.IsEmpty = False Then
        For i = 0 To EventInfo.UserData.GetCount - 1
            Select Case EventInfo.UserData.Get(i).Key
                Case "GSW_USER_EVENT"
                    handle_user_event EventInfo, EventInfo.UserData.Get(i).StringValue
                Case "GSW_ERROR"
                        Debug.Print "Error: " & EventInfo.UserData.Get(i).StringValue
                        RaiseEvent TError(EventInfo)
                Case "GSW_APPLICATION_ID"
                    If EventInfo.UserData.Get(i).Type = 0 Then
                        GSW_APPLICATION_ID = EventInfo.UserData.Get(i).StringValue
                    Else
                        GSW_APPLICATION_ID = EventInfo.UserData.Get(i).NumValue
                    End If
                Case "GSW_RECORD_HANDLE"
                        GSW_RECORD_HANDLE = EventInfo.UserData.Get(i).StringValue
                    Else
                        GSW_RECORD_HANDLE = EventInfo.UserData.Get(i).NumValue
                    End If
                Case "GSW_CAMPAIGN_NAME"
                        CAMPAIGN_NAME = EventInfo.UserData.Get(i).StringValue
                    Else
                        CAMPAIGN_NAME = EventInfo.UserData.Get(i).NumValue
                    End If
            End Select
        Next i
    End If
End Sub[/code]
HANDLE USER EVENT METHOD
[code]Private Sub handle_user_event(EventInfo As DesktopToolkitX.TEventInfo, UsereventType As String)
    Dim i As Integer
    Select Case UsereventType
        Case "PreviewRecord"
            Call set_m_chainedphones(EventInfo, True)
            Call ChainedRecordRequest(CAMPAIGN_NAME)
        Case "ChainedRecord"
            Call set_m_chainedphones(EventInfo, False)
        Case "ChainedRecordsDataEnd"
            RaiseEvent TEventChainedRecordEnded(EventInfo)
    End Select
End Sub[/code]
The basic idea in the above logic is:
1. Call the RequestPreviewrecord
2. Catch the PreviewRecord ACK that the server sends,read the attached data that contain some basic customer info and put the customer's phone ,the GSW_RECORD_HANDLE,GSW_CALL_ATTEMPTS,GSW_CALL_RESULT in the 1st line of an array.
3.  Then call a ChainedRecordRequest catch subsequent events that the server sends and further fill up the phones array.
4.Upon receiving the ChainedRecordsDataEnd ACK i raise an event that's listened by the crm application that does it;s stuff
 (reads the phones array and the customer data that's handled from the OCS)
