Author Topic: I need a Sample Code on Rescheduling an Outbound Call  (Read 8593 times)
tkardaridis
« on: May 21, 2007, 02:50:04 PM »
I am new on this forum but not on Genesys. I had develop two months ago a softphone and now i have to implement also Rescheduling Outbound Call. I create a KeyValueCollection with the required parameters.
I don't know two things.
1. How should i retreive the GSW_RECORD_HANDLE in order to attach it on the KeyValueCollection? From where can i find it? Does it exists on the AnswerCall and How should i found it?
2. Which Request should i use in order to fire the Request on T-Server in order to Reschedule the Call?
Any sample code would be very very helpfull.
Thomas
Re: I need a Sample Code on Rescheduling an Outbound Call
« Reply #1 on: May 21, 2007, 07:01:19 PM »
  • The record handle arrives on the Event_Ringing for example.
    It will be a good idea that you add a eventlog object so you can see all what happens on your DN.
    To reschedule just send the event any time with the required format.
    Search here, there a couple of codes for examples
    « Reply #2 on: May 23, 2007, 07:51:50 AM »
  • There is a sample VB application with source code that I have posted here a while back that will do just that. Take a look at it because it should cover most of your questions. Please tell me if you cannot find it and I will upload it again.
    Needless to say, please ask questions about the source code, if something seems weird :) (Please remember that I put it together in less than an hour, so please do not expect it to work perfectly in a full production environment!) ;)
    Best regards,
    tkardaridis
    « Reply #3 on: May 23, 2007, 01:37:30 PM »
  • Thanks a lot for your replies. Victor i cannot find the sample VB application. Could you please upload it again and send me the url i can download it?
    Best Regards,
    Thomas
    « Reply #4 on: May 23, 2007, 04:48:11 PM »
  • search for visual + basic + code it's not a file, it's plain text.
    « Reply #5 on: May 24, 2007, 10:23:59 AM »
  • Ok, here we go - I put together something for you - I did not have time to play with date/time yet, but all you need to do is add the time field and you are set.
    This application will let you login.logout, join/leave campaign, ask for the next record, enter the data, update the status of the record.  So, what you need to do is just one more field for date :)
    Needless to say, please re-write it to make it more useful for you - I only spent about 15 minutes on it.
    I will try to play with the date tomorrow if you need more help :)
    Best regards,
    « Reply #6 on: May 29, 2007, 01:35:24 AM »
  • Hi,
    did you have any luck with GIS reschedule? I did not get a chance to install or play with it so far. :(
    Did you manage to do it on your own?
