" /> Using GVP for treatments - Genesys CTI User Forum
Author Topic: Using GVP for treatments  (Read 4179 times)
Offline Kevin S
« on: May 03, 2007, 07:48:56 PM »
In the past, I've used VTO for providing in-queue treatments in a Nortel environment. I'm now in a new environment (NEC) that does not have VTO but wants to provide more advanced in-queue treatments than the switch can provide.
I understand that VTO is being phased out, and I know that GVP does have some cells (steps, etc) for handling Treatments.
My question is: could someone provide an example application where GVP is utilized to give treatments? While the user's guide provides hints that it can be done, I have not found any guidance on HOW to do it.
Thanks in advance.
Offline CTIgem
Re: Using GVP for treatments
« Reply #1 on: May 03, 2007, 08:21:06 PM »
Go to support site and go to tech tutorials.
they have GVP integration with URS.
VTO phasing out?
Where can I find offical doc about it?
Offline Kevin S
« Reply #2 on: May 04, 2007, 03:29:32 PM »
I do not have a formal document on it, but was told this during a recent conversation with a Genesys employee familiar with GVP.
This person also did not have any information about dates, etc, but phrased it as there were not plans to release VTO 7.5 .
Offline Adam G.
  • Still Gorgeous.......
« Reply #3 on: May 08, 2007, 08:53:12 AM »
I believe Voice Genie will be for the smaller sized implementations and GVP will be used for the large deployments.
« Reply #4 on: May 16, 2007, 04:36:01 AM »
[quote author=Kevin S link=topic=2211.msg7908#msg7908 date=1178221736]
Thanks in advance.
You can use GVP as an IVR , and then just use IVR treatments in strategy to forward the calls to GVP for handling.
« Reply #5 on: May 16, 2007, 06:37:14 AM »
On the treatments of the target select IVR:
put ivr_place_group@statserver and the script ID.
Should work
