" /> How to export DNs from CME into a file?Hi - Genesys CTI User Forum
Author Topic: How to export DNs from CME into a file?Hi  (Read 3990 times)
Koki
« on: May 01, 2007, 09:30:21 AM »
I have a quick question on how to export data from Swtich->DN folder of Configuration Manager into a file. We have thousands of DNs separated into sub-folders, and I need to print out content of one of those sub-folders. How can I do it?
Thank you veyr much,
[move][glow=green,20,1000]Koki :)>[/glow][/move]
Marked as best answer by on March 14, 2025, 12:18:38 PM
Offline Adam G.
  • Still Gorgeous.......
Re: How to export DNs from CME into a file?Hi
« Reply #1 on: May 01, 2007, 09:42:07 AM »
  • Undo Best Answer
  • How about writing a quick Hyperion report from the config DB?
    Pavel
    « Reply #2 on: May 02, 2007, 10:32:35 AM »
    Here is a basic SQL script that will do that fo you:
    [table][tr][td][/td][td]
    [size=8pt]SELECT    cfg_dn.number_, cfg_dn.name, cfg_switch.name AS Switch, cfg_locale.lc_value, ISNULL(cfg_folder.name, 'Root Dns') AS Folder_Name
    FROM        cfg_dn INNER JOIN
                          cfg_locale ON cfg_dn.type = cfg_locale.lc_subtype LEFT OUTER JOIN
                          cfg_switch ON cfg_dn.tenant_dbid = cfg_switch.tenant_dbid LEFT OUTER JOIN
                          cfg_obj_folder ON cfg_dn.dbid = cfg_obj_folder.object_dbid LEFT OUTER JOIN
                          cfg_folder ON cfg_obj_folder.folder_dbid = cfg_folder.dbid
    WHERE    (cfg_locale.lc_type = 5)
    GROUP BY cfg_obj_folder.folder_dbid, cfg_locale.lc_value, cfg_dn.name, cfg_dn.number_, cfg_switch.name, cfg_folder.name[/size]
    [/td][/tr][/table]
    I hope it helps:)
