Author Topic: Handling TServer responses in Java  (Read 5756 times)
« on: April 26, 2007, 09:03:46 AM »
I am very curious about how to handle TServer responses in Java.
I have noticed that each command gets a reply right away.
Is it the correct way to program?
I am concerned that by waiting for response significantly slows down the system.
[size=8pt]
  Message request =
    RequestRegisterAddress.create(
      "2700",                                      //DN
      RegisterMode.ModeShare,
      ControlMode.RegisterDefault,
      AddressType.DN
  Message response = protocol.request(request);
  if(response.messageId() != EventRegistered.ID)
    throw new Exception("Unexpected response to RequestRegisterAddress");
[/size]
I am thinking about building a proxy for TServer, thus the need to issue more than one request regardless of whether or not we got a reply. Can this be done with Java? Or do I need to open a new connection for each new DN??? This would really be worst possible thing to do.
Isn't there a way to implement some sort of callback function instead? Like we used to have in ActiveX version?
s.kulku
Re: Handling TServer responses in Java
« Reply #1 on: May 02, 2007, 10:44:04 AM »
Vic,
please tell me if you figure it out!
Sanja Kulku
Technical Product Manager
