Author Topic: Origination Access Blocking  (Read 4137 times)
Offline CTIgem
« on: April 10, 2007, 03:51:14 PM »
This is more like switch issue but I need to know what's causing it.
Getting "Origination Access Blocking" only for one number when making outbound call.
Any other number is ok.
Any idea?
Re: Origination Access Blocking
« Reply #1 on: April 10, 2007, 05:02:19 PM »
Genesys doesn't block numbers you can dial, your PBX does. Can this number be dialed from any other administrative set?
Offline CTIgem
« Reply #2 on: April 10, 2007, 05:54:27 PM »
Other phones are same since all phones are programmed same way as below.
TGAR = 10
NCOS = 1
CLS = CTD
What setting in the switch blocks that call?
« Reply #3 on: April 10, 2007, 06:38:35 PM »
CTIgem,
what PBX/switch are you talking about?
Offline CTIgem
« Reply #4 on: April 10, 2007, 07:07:50 PM »
Nortel Meridian Option 11 or they changed name to "Nortel communication server 1000".
