Author Topic: SMTP mail failing from SCS on alarm conditions in SCI  (Read 9324 times)
Offline mark
« on: April 10, 2007, 02:37:43 PM »
I am getting the below error in my log when testing an alarm condition and reaction. I would like to send an email when that alarm is activated, but Genesys doesn't like me today, so it's giving me errors.
[code]Test Condition <144, mw1>, Test MessageID = 20000
CREATE ActiveAlarm  <144, mw1> for  App=<184, reph_datasourcer_b>, createTime=1176214216
15:10:16.741  Trace  sdorg001  mng_scs_p  GCTI-43-10612  Active Alarm 'mw1' created for Application 'reph_datasourcer_b'
15:10:16.741  Alarm  sextg016  reph_datasourcer_b  GCTI-00-04115  mw1, alarm condition(144)
15:10:16.741  Alarm  sextg016  reph_datasourcer_b  GCTI-00-04200  Active Alarm "mw1" Created (ID=21182630-C8E5-4372-BC8B-108F796DEAFB)
ActiveAlarm::SetDeleteTimer  <144, mw1> for App=<184, reph_datasourcer_b>, LastSetTime=1176214216, timeout=172800
15:10:16.756  Standard  sdorg001  mng_scs_p  GCTI-43-20705  Request to create alarm 'mw1' for application 'reph_datasourcer_b' issued by 'woodrm1' (684)
!Execute all Reaction for AlarmCondition <144, mw1>
15:10:16.756  Trace  sdorg001  mng_scs_p  GCTI-43-10500  Reaction 'mw1' activated
Reaction text: An alarm has been detected by Genesys Solution Management Layer.
Alarm Reaction: mw1
Alarm Condition:
category: Major
Application:
Type: DataSourcer
Message:
Msg description:
[b]15:10:16.756  Standard  sdorg001  mng_scs_p  GCTI-43-10315  Unable to execute AlarmReaction 'mw1' of type 'Reaction_SendEmail' for AlarmCondition 'mw1' [from App 'reph_datasourcer_b'], error [Mailer is not initialized successfully]
15:10:16.756  Standard  sdorg001  mng_scs_p  GCTI-43-10220  Unable to execute Reaction 'mw1'[/b]
### MESSAGE#=4115, 'mw1, alarm condition(144)'
CREATE ActiveAlarm  <143, DataSourcer Application Failure> for  App=<184, reph_datasourcer_b>, createTime=1176214216
15:10:16.756  Trace  sdorg001  mng_scs_p  GCTI-43-10612  Active Alarm 'DataSourcer Application Failure' created for Application 'reph_datasourcer_b'
15:10:16.756  Alarm  sextg016  reph_datasourcer_b  GCTI-00-04115  DataSourcer Application Failure, alarm condition(143)
15:10:16.756  Alarm  sextg016  reph_datasourcer_b  GCTI-00-04200  Active Alarm "DataSourcer Application Failure" Created (ID=AEB5985C-DDBF-453C-AF4A-310378FDA688)
ActiveAlarm::SetDeleteTimer  <143, DataSourcer Application Failure> for App=<184, reph_datasourcer_b>, LastSetTime=1176214216, timeout=172800
Found Condition <143, DataSourcer Application Failure>, Detect Message = 4115
!Execute all Reaction for AlarmCondition <143, DataSourcer Application Failure>
[/code]
Does anyone have any idea as to what could be stopping the emails being sent? I have had a scan of the Genesys solutions and 1 example comes up, which is not relevant to us (according to our server / email guys).
I have added the mailer category to SCS (both primary and backup) with 3 options:
smtp_from
smtp_host
smtp_port
all 3 option values have been confirmed as ok.
Your help, as always, would be appreciated :
Mark
Offline catanirex
Re: SMTP mail failing from SCS on alarm conditions in SCI
« Reply #1 on: April 10, 2007, 02:53:22 PM »
Maybe your Anti-Virus is stopping applications from using port 25 for SMTP?
In McAfee: Open VirusScan Consol, Open Access Protecion and check if port 25 is blocked
« Last Edit: April 10, 2007, 02:57:29 PM by catanirex »
Offline mark
« Reply #2 on: April 10, 2007, 03:20:40 PM »
Good suggestion, have checked this and port 25 is open to be used.
CTIgem
« Reply #3 on: April 10, 2007, 03:44:54 PM »
You have outlook installed.
« Reply #4 on: April 10, 2007, 03:52:09 PM »
Hi Mark,
Have you restarted SCS after adding the options related to SMTP? SCS tries to initialize the mailer engine at the start-up only.
Cheers,
René
Offline mark
« Reply #5 on: April 10, 2007, 08:58:52 PM »
[quote author=CTIgem link=topic=2167.msg7650#msg7650 date=1176219894]
Nope, outloook is not installed on this server, its not trying to use MAPI.
Offline mark
« Reply #6 on: April 10, 2007, 09:00:46 PM »
[quote author=René link=topic=2167.msg7652#msg7652 date=1176220329]
Hi Mark,
Cheers,
René
Could well be the problem, we are planning to restart most things tomorrow evening before go live of another area on Thursday, that may resolve the issue.
The documentation mentions that adding the options take effect immediately, but it would not be surprising for it to need a restart!
Will restart tomorrow and come back with the results :]
Mark
« Reply #7 on: April 11, 2007, 08:27:47 AM »
I know what the documentation says but unfortunately it isn't true. Any changes related to the settings of the mailer engine do require restart of SCS to be applied.
Offline mark
« Reply #8 on: April 11, 2007, 10:18:32 AM »
[quote author=René link=topic=2167.msg7673#msg7673 date=1176280067]
Just another silly documentation error then :D
Restart scheduled for tonight :]
Mark
« Reply #9 on: April 11, 2007, 10:29:17 AM »
I've just checked the documentation for SCS 7.5 and it's fixed there - any changes to the options "smtp_host" and "smtp_port" are applied after restart ;)
Offline mark
« Reply #10 on: April 12, 2007, 12:25:32 PM »
[quote author=René link=topic=2167.msg7678#msg7678 date=1176287357]
Ah ha, that's about right!
Restart last night, started to get 'SMTP 501:SMTP server error' in SCS log, looks like it didnt like the email address and name, changed it to the raw email address and it worked.
eg: smtp_from: Genesys Alarm <genesys@myemailaddress.co.uk> - will not work
however, smtp_from: genesys@myemailaddress.co.uk will work.
All good now, I can create some proper detections and reactions!
Thanks René
Mark
« Reply #11 on: April 12, 2007, 12:37:46 PM »
Hi Mark,
Good to know it's working now :)
If you want to specify personal part for the email address then the format has to be like - smtp_from: "...personal part..." <...email address...>
Cheers,
René
